Thread: Check engine light help!!!
Results 1 to 15 of 15
  1. #1 Check engine light help!!!
    Jul 2015
    St Louis mo
    I have a 04 gtp. Check engine light came on, p0141 downstream sensor. So I replaced it, had code reset, 3 days later, this morning tje light came back on and hasnt gone off?? Any thoughts would be great.
  2. #2 Re: Check engine light help!!!
    Check the wiring harness.
    Possible Solutions
    Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
    Repair short or open or high resistance in wiring harness or harness connectors
    Read more at: http://www.obd-codes.com/p0141
    Copyright © OBD-Codes.com
  3. #3 Re: Check engine light help!!!
    Jul 2015
    St Louis mo
    Yea that was my next step. Should I check the ecu were it runs to? Looks like under the air box I glanced after work tonight were it ran
  4. #4 Re: Check engine light help!!!
    No check the part of the wire harness that comes off the back side of the engine and goes down under the car, that is most likely where the bad spot is.
    Sent from A Galaxy Far Far Away
  5. #5 Re: Check engine light help!!!
    Jul 2015
    St Louis mo
    Ok will do and ill keep you posted. Had it scanned before work this morning same code p0141. Got told that it could be the cat converter,and that bank one sensor two is the front sensor by the header? Incorrect I thought it was the downstream passed the cat?
  6. #6 Re: Check engine light help!!!
    St. Louis
    Bank 1 sensor 1 is the one is the exhaust manifold that blocks easy access to #6 spark plug. Sensor 2 is post-cat converter.
  7. #7 Re: Check engine light help!!!
    Jul 2015
    St Louis mo
    Exactly what I thought so I replaced the right one. Gunna check fuses and wiring and go from there really frustrating tho
  8. #8 Re: Check engine light help!!!
    Quote Originally Posted by FordMan77 View Post
    Yes but this code is bank 1 sensor 2. P0141
  9. #9 Re: Check engine light help!!!
    Enfield, CT
    Hmmmm. I would check fuses. My 97 used to tell me my downstream o2 was shot whenever I blew the cig lighter fuse. Since its an 04, I don't think it's the cig lighter fuse but might be worth checking out.
    Sent from my LG G3
  10. #10 Re: Check engine light help!!!
    Quote Originally Posted by Slick2500 View Post
    bank 1, sensor 2 is the post cat o2. we only have one bank with 2, o2 sensors. up and down steam.
    and its the heater circuit code. means the heater inside the o2 is failed. so bad wires, or its a bad o2 you got try a delco
  11. #11 Re: Check engine light help!!!
    Jul 2015
    St Louis mo
    Im finally off work tomorrow so Im gunna check the fuses first, then the wiring. Just sucks the the wiring has that protected crap around it so u gotta cut it off to even see them. Hoping for a fuse. And as far as the o2 sensor being bad I dont wanna waste more money and put another one in and it still be on
  12. #12 Re: Check engine light help!!!
    What brand o2 sensor did you buy?
  13. #13 Re: Check engine light help!!!
    Quote Originally Posted by Caloia1 View Post
    There is about 3-4 feet of wire for that sensor that isn't in the harness.
  14. #14 Re: Check engine light help!!!
    Jul 2015
    St Louis mo
    The brand was ultra power. Found online for $35 bux. And yea ill check that 4 foot section,but if theres nothing there damaged I probably need to check the harness after that wouldn't u think. Im pretty good with cars but never really diagnosed a check engine light code like this.
  15. #15 Re: Check engine light help!!!
    Jul 2015
    St Louis mo
    And that Sensor was a bi### to get out by the way. Had to put on a lift and use a 3 foot breaker bar
  1. Check engine light
    By 0GTP4 in forum General Tech Discussion
    Last Post: 02-11-2012, 11:24 AM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. Check engine light on
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2010, 10:11 PM
  5. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
