Thread: Engine Trouble
Results 1 to 20 of 24
  1. #1 Engine Trouble
    Jul 2015
    Michigan
    Hello, I'm new here but in desperate need of help and thought maybe I could get an answer here.
    I have a 2002 GTP. I was cruising down the freeway at 70. My boost meter started freaking out going up and down up and down. Then the car started bogging out, slowing down. I pulled over and shut it off. When I started it back up to see what was going on under the hood, the car was sputtering and shaking pretty bad. The oil looks good, not milky. The motor has recently been replaced, and only had 59,000 miles on it when it was put in. The head gasket was replaced when the motor was swapped. The car itself has around 150,000. The motor didn't come come with a supercharger so the old one was used. Do you think the Supercharger is shot completely? Someone suggested O2 sensor, but it seems more severe than that.
  2. #2 Re: Engine Trouble
    did the check engine light come on? if so did you scan it? if you did whats the code?
    if the light is on get it scanned, the code is the key.
  3. #3 Re: Engine Trouble
    Oct 2014
    portland oregon
    any mods?
  4. #4 Re: Engine Trouble
    Jul 2015
    Michigan
    The check engine light was on, yes. I haven't had it scanned for any codes yet. The car is at a gas station at the moment. Luckily I wasn't far from my Grandpa's house and he came and picked me up. We're borrowing a trailer to go pick it up tomorrow.
    No mods.
  5. #5 Re: Engine Trouble
    get the code and post back. it will tell you where to start.
  6. #6 Re: Engine Trouble
    Jul 2015
    Michigan
    Ok, will do. Thank you for the quick reply and the help.
  7. #7 Re: Engine Trouble
    Jul 2015
    Michigan
    Update: it threw 2 codes. Both said cylinder 4 is misfiring. Does that mean anything other than what it says? I'm mechanically inclined enough to tear it down and put it back together, but I have no clue what I'm doing when it comes to diagnosing issues on these electronically run motors.
  8. #8 Re: Engine Trouble
    Please post the codes and the descriptions. There shouldn't be two codes for Cyl 4 only.
  9. #9 Re: Engine Trouble
    we need the codes for sure. could be a injector or a spark plug or a plug wire, or a coil.
  10. #10 Re: Engine Trouble
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    Both cyl4 codes? Perhaps you meant a randomn misfire code and a cyl4 code.
  11. #11 Re: Engine Trouble
    Jul 2015
    Michigan
    I don't personally have a computer, so I took it to Autozone (not reliable, I know :/) and that's what they said. I didn't get the codes so I can't post them unfortunately. I dropped it off to a shop to be looked at and just from the brief look he took at it he said he thinks it blew a spark plug. Which would make sense if the codes are showing a cylinder misfire.
  12. #12 Re: Engine Trouble
    my auto zone prints out the codes and the description of the code and hands it to me. the scanner they use is just fine.
    if the spark plug is smashed, you chipped a piston and its on its last leg.
  13. #13 Re: Engine Trouble
    Jul 2015
    Michigan
    The one here didn't do that. She just read the description to me.
    God I hope not... literally just put that motor in a few months ago. I love the car, but I paid 4500 for it 2 years ago, and since then have put over 4000 into it... could've got a hell of a nice car for that much.
  14. #14 Re: Engine Trouble
    I still don't understand what "blown plug" means. Fords literally blow the plug out and dent the body. These cars have cast iron heads, so that's not possible.
  15. #15 Re: Engine Trouble
    go back and ask them to write the code down. thats some BS.
    and fyi: you can buy a code scanner for under 20 shipped off ebay, they work just fine. i got a cheap-0 one a while back, got fed up with the free scan at autozone.
  16. #16 Re: Engine Trouble
    Jul 2015
    Michigan
    I would but we already unloaded it at a mechanic shop. I should be getting a call within a day or two, he was pretty busy.
    I'll keep updating though. When I hear from him what he says is wrong with it I'll post it here and see what you guys think.
  17. #17 Re: Engine Trouble
    Jul 2015
    Michigan
    Got a call today. Cylinder 4 is dead. Absolutely no compression. I'm thinking maybe the company that i bought the engine from sent me one that wasn't supercharged. The boost on a non supercharged motor could've shot the cylinder.
  18. #18 Re: Engine Trouble
    Im super f ed then being in on na bottom end. How about you got a beat used engine.
  19. #19 Re: Engine Trouble
    Jul 2015
    Michigan
    I'm just not sure how it could've been that screwed with 59000 miles on it. Either they lied on the mileage, or it wasn't a supercharged engine I think.
  20. #20 Re: Engine Trouble
    how long has it been in the car now? did it run ok from day one? if it ran poorly from day one its a beat engine.
    if you bring it back to the junk yard they should replace it within so many months for free. sadly you eat the labor on the swap.
  1. 98 gtp new guy engine trouble
    By JayHolyj in forum Introductions/Noob Questions
    Last Post: 02-20-2012, 11:58 AM
  2. Engine trouble?
    By DCGTP in forum General Tech Discussion
    Last Post: 01-25-2012, 01:57 PM
  3. 3.8 engine trouble
    By mjacob in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2011, 11:37 AM
  4. Engine Trouble
    By 98GTFan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-10-2011, 03:58 PM
  5. Engine Trouble!! need help!
    By ddrum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-12-2010, 04:41 PM
