Thread: finally got it running
Results 1 to 20 of 20
  1. #1 finally got it running
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Well after about a year and a half it started
    https://youtu.be/re1shn06UFY
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  2. #2 Re: finally got it running
    it just needs the cat back bolted back on lol and a blower belt.
  3. #3 Re: finally got it running
    Aug 2011
    Gahanna, Ohio
    I jerry rigged the catback on. . Then the brake pedal went to the floor. The 182k mile brake lines finally whit the bed. Oh well.
  4. #4 Re: finally got it running
    Aug 2011
    Gahanna, Ohio
  5. #5 Re: finally got it running
    why so much surge? it have a vac leak?
  6. #6 Re: finally got it running
    Aug 2011
    Gahanna, Ohio
    Havent done any tuning other than copy the fuel and spark over from a dhp 1.5 bin. Cant drive it because of the brake line.
  7. #7 Re: finally got it running
    bump the idle up if its not a vac leak.
    brakes, you kinda need them... next on the list i bet.
  8. #8 Re: finally got it running
    Aug 2011
    Gahanna, Ohio
  9. #9 Re: finally got it running
    Aug 2011
    Gahanna, Ohio
    Yeah i got under it and its spraying right behind the steering rack. Its the line that runs over the to the passenger side front. Ill deal with it another day. Im sore
  10. #10 Re: finally got it running
    reducer issues i see. that blows. you need to just get that all welded up nice.
  11. #11 Re: finally got it running
    Aug 2011
    Gahanna, Ohio
    Its only so i can drive it. In about 2 weeks my welder buddy is going to put on 2 2.5" magnaflow resonators and im going to dump it out the rear passenger door.
    That and i think the vband clamp for the headers is shot... $50 sd headers so i cant complain too much.
  12. #12 Re: finally got it running
    and i thought i did good with 100 dollar used headers lol
  13. #13 Re: finally got it running
    Aug 2011
    Gahanna, Ohio
    Ha. Yeah they were trashed. Flex was all ripped. Chavo on here parted out his gtp earlier this year. Got the flex from zzp and for a 12 pack of summer shandy got the flex fixed . I wanted to wire wheel them to clean them up but i didnt have the time.
  14. #14 Re: finally got it running
    mine look like hell too lol i just did a engine swap, so while it was out i had a friend weld up a v band clamp set up on the new flex to header, then welded in the cat and the reducer. so much nicer then clamps i was using.
  15. #15 Re: finally got it running
    Aug 2011
    Gahanna, Ohio
  16. #16 Re: finally got it running
    i painted mine silver when they were out, and well, that didnt work out so good lol
  17. #17 Re: finally got it running
    Aug 2011
    Gahanna, Ohio
    Was it high temp 1500* stuff? I used vht on my old s&s headers and it stuck forever. Theres was a cure procedure you do and it worked good. I wanted to header wrap mine but didnt have time.i was hell bent on starting it yesterday.
  18. #18 Re: finally got it running
    it was duplicolor hi heat header paint iirc. it came off seconds after starting it up for the first time. funny how it stayed on the flange tho.
  19. #19 Re: finally got it running
    Aug 2011
    Gahanna, Ohio
    Probably because the headers are stainless steel. The flanges arent.
  20. #20 Re: finally got it running
    im thinking its because the pipes are so much thinner they heat up really fast and get hotter then the thick ass flange.
  1. Finally Running, but stalls
    By ThePhoenix98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2014, 01:55 PM
  2. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  3. 03 Top Swap running hot UP AND RUNNING
    By The Guz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2013, 02:19 PM
  4. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  5. The MP112 GTP Is FINALLY Running!
    By VinnieGTP in forum General Tech Discussion
    Last Post: 07-31-2008, 04:10 AM
