Thread: 1997 Grand Prix GTP, flex plate change out
Page 3 of 3 FirstFirst 123
Results 41 to 42 of 42
  1. #1 Re: 1997 Grand Prix GTP, flex plate change out
    The point I was getting at about correct maf data is.. you might see something. But if the maf isn't seeing the "correct" amount according to the pcm parameter.... it doesn't give you fuel.
    No fuel, no start.
    The way our vehicles work is you turn the key, the fuel pump runs for a second to prime the system up to the right pressure. The maf even while cranking can give you a reading to keep the injectors closed. Yes...I know this because I've run across it.
  2. #2 Re: 1997 Grand Prix GTP, flex plate change out
    Oklahoma
    It seems I just trashed the new starter. So I'm done. I appreciate everyone's input.
  1. flex plate
    By Eric Whitter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-31-2013, 09:52 PM
