Thread: Supercharger seized up wont turn any fix?
Results 1 to 20 of 35
  1. #1 Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    I have a Gen V blower giving to me off cl off a 04 gtp demod i was tryna flip the money and resell lol but it wont turn nor spin like its seized up.. Any thing i can do to save it or do .. Thanks?
  2. #2 Re: Supercharger seized up wont turn any fix?
    Open it up.
    Either the snout bearing is siezed or the rotor pack bearing is, thus locking the rotors together.
  3. #3 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    Open it up.
    Ok i will
  4. #4 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    Also what can i do to unlock them if they are seized?
  5. #5 Re: Supercharger seized up wont turn any fix?
    Feb 2013
    Missouri
    Replace the seized bearings.
  6. #6 Re: Supercharger seized up wont turn any fix?
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    WD40, lol.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  7. #7 Re: Supercharger seized up wont turn any fix?
    Feb 2013
    Missouri
    If you are that far in there and the bearings were bad enough to lock up, it's a no brainer IMO.
  8. #8 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    Wd 40 was my first thought lol dammit it doesnt work lol i will replace the bearings...
  9. #9 Re: Supercharger seized up wont turn any fix?
    Can't use WD40 on the SC. The needle bearings have a grease in them that isn't standard grease.,
    Personally.. put a belt on the pulley.. then grab your three foot blue point channel locks and see if it'll move. If not.. I bet you have much bigger issues inside than a bearing. Because.....how many of us have ever seen a locked up bearing on an SC?
  10. #10 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    Check every thing when i get hm...got it for free ... So idk wth he did but he was parting out his 04 gtp and i wanted the LIM said i could have the blower but told me it wouldnt turn so im tryna fix it if not... scrapyard it goes.
  11. #11 Re: Supercharger seized up wont turn any fix?
    Then there's a chance he pulled it apart at some point.
    The needle bearings in the case may have gotten messed up and one might be pinned in there and stopping the pack from turning. I'd start by seeing if they are just tight and seeing if you can turn it. Then I'd go to disassembly and inspection. There's so little to go wrong.
  12. #12 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    Oh ok might explain how easy it opened lol.. Well i will try and check things later.. Hopefully i can get it to spin... Has a mps on it
  13. #13 Re: Supercharger seized up wont turn any fix?
    Apr 2015
    Columbus, OH
    I'd be amazed if it was just a bearing issue. I know Jeff has worked on dozens of blowers, wonder what he thinks. Possible some shrapnel got sucked in and jammed the rotor pack in the case, maybe.
    Top Swapped 01 Imp
  14. #14 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    Ok i will take pic ...of blower opening it up
  15. #15 Re: Supercharger seized up wont turn any fix?
    If you got it open w/o fighting at least one of those torx bolts, it's been open before. There is always one that fights
  16. #16 Re: Supercharger seized up wont turn any fix?
    I had a locked up GEN 5, I couldnt even get the rotor pack out. After a year of sitting on the shelf I sold the snount and scrapped it.
  17. #17 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    Sheesh might have to part out... Try and see... What could i use.. Vice grips channel locks?
  18. #18 Re: Supercharger seized up wont turn any fix?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Holy crap dude, that's stuck! You weren't curious enough to beat the snot out of it to see what the issue was?
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  19. #19 Re: Supercharger seized up wont turn any fix?
    There are a couple of notches that are between the case and rotor pack. It's meant to be pushed apart with a tool. I have a sears one that has two flat pieces and when you squeeze the handle..it pushes them apart.
  20. #20 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    Ok if the flathead trick i have doesnt work i will try and grab this piece any idea what its called?
  1. wont turn over...
    By dklonewolf in forum General Grand Prix Discussion
    Last Post: 09-15-2013, 02:34 PM
  2. Key wont turn
    By RedGrandprixgt53 in forum General Tech Discussion
    Last Post: 12-02-2011, 04:27 PM
  3. TCS wont turn on
    By jmalin72207 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 01:19 AM
  4. please help, air wont turn off
    By red60degreeGP in forum General Tech Discussion
    Last Post: 04-23-2009, 06:26 PM
  5. My Car wont Turn off !!!
    By Billyboi6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-15-2008, 01:02 AM
