Ok question. I am going to be upgrading to 42# injectors, they have the older style clips. I got a set of clips and a known good set of older 97-03 L67 injectors. I soldered and heat shrunk the clips on and put in the older style injectors into my 04 comp g.
Now even using the 97-03 injector flow rate table or the 04 injector table I still see 10 to 1 afr on my wideband under quarter throttle. Any higher and it just pegs out super rich.
My question is has anyone else ever done this and got it to run good? And what should my injector table look like to make these work?
