Most people do one or the other, meaning, either a cam or rockers. Gains are similar either direction, but together not significant. You can run both, and I've seen a couple of builds that way. But it for sure will require different length push rods. Stock heads are fine. The suggestion is anything over #110 or #125 springs needs double roller timing at least. Which also means machined front cover, etc.
