Thread: 3.5" or 3.6" pulley
Results 1 to 12 of 12
  1. #1 3.5" or 3.6" pulley
    Mar 2015
    USA
    I'm finally ready to give in to temptation and drop pulley size.
    The zzp charts are a little confusing. The car is a 2004 Impala SS, but they say 3.5 should be stock. Mine is no doubt 3.8.
    I'm running Autolite 104 plugs, 180 tstat, 2.5" catless zzp downpipe, and a very basic tune. Have at most .2-.5 of kr under very heavy acceleration.
    Can I do a 3.5, or err on the side of caution and go 3.6?
  2. #2 Re: 3.5" or 3.6" pulley
    Mar 2012
    NC
    Running the 3.5 or 3.6 is going to net you more KR...I'd do other mods first...PLOG or rockers then pulley.
  3. #3 Re: 3.5" or 3.6" pulley
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    zzp charts are complete BS ... don't drop pulley until you see 0 kr. that .2 -.5 will likely turn into much bigger numbers when you put a smaller pulley on , even a 3.6 .
    upgrade your intake and consider getting a powerlog . then rescan and go from there.
    even though zzp's chart is BS info , keep in mind a gen V SC needs more supporting mods than a gen III. their claim of a 3.5 being ok for stock is for gen III and it's still wrong.
    read this thread....twice
    http://www.grandprixforums.net/threa...00-Powered-Car!!
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  4. #4 Re: 3.5" or 3.6" pulley
    Mar 2015
    USA
    Quote Originally Posted by EHB View Post
    FWIW, my car has a Gen 3 blower on it. Hence some confusion, their website makes it sound like it should be a Gen5.
    The .2-.5 or so is really worst case. I could make a few WOT passes thru the gears and not see anything. Gonna order the plog for not to quench my need to mod.
    Intake is the stock airbox with a K&N drop in. I seem to recall reading somewhere the 04+ air boxes actually flow a lot better than the older ones.
  5. #5 Re: 3.5" or 3.6" pulley
    Idk why but that just seems like a lot of knock for a car with a downpipe, colder plugs, and a colder tstat on a stock pulley. I am willing to bet that if you had a better tune you could run a 3.6.
    Yup only cars that got the Gen 5 were the 04+ GPs. IIRC after 2005 they were the only cars available with a supercharged 3800.
  6. #6 Re: 3.5" or 3.6" pulley
    Dec 2014
    Maryland
    Quote Originally Posted by 2004l67 View Post
    ok well the fact that you're seeing any knock on the mods you already do have with the gen III , proves that zzp is full of crap. you've already went beyond what they say you need and still see kr. what did you gap your plugs at ? are you using 93 octane? the amount of kr you're getting isn't a big deal in itself , but as slick pointed out , you shouldn't be getting any at all. the plog will wipe out the rest. put the plog on and get the 3.5 , scan and retune accordingly.
  7. #7 Re: 3.5" or 3.6" pulley
    Mar 2015
    USA
    I want to say I gapped them at .50.
    Think I'm fine with that k&n drop in, or would I be better suited to some sort of FWI? I played around with a cone filter and a little bit of piping, but couldn't get it into the fender enough to shield it from engine heat.
  8. #8 Re: 3.5" or 3.6" pulley
    Lol engine heat.
    Flow > Temps.
    Unless you plan on making some exhaust system that routes the crossover under the transmission, it's not going to make a difference no matter what intake you come up with.
  9. #9 Re: 3.5" or 3.6" pulley
    Mar 2015
    USA
    Quote Originally Posted by blueguy View Post
    Flow > Temps.
    Makes sense. The SC is compressing it the same regardless of hot or cold. I'm just stuck in a NA mindset where cooler air is denser and betterer.
  10. #10 Re: 3.5" or 3.6" pulley
    Dec 2014
    Maryland
    you could always wrap the cross over with header wrap . not sure how much it helps , but it certainly can't hurt none.
  11. #11 Re: 3.5" or 3.6" pulley
    Slap a cone on the end of the throttle body and call it a day.
  12. #12 Re: 3.5" or 3.6" pulley
    It wouldn't hurt anything...but it probably wouldn't help much either.
  1. 3.5 pulley, TB Spacer, PLOG, other "go fast" goodies
    By GTPlzz in forum Wanted To Buy - Parts
    Last Post: 02-13-2014, 04:27 PM
  2. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  3. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
