Thread: Springs loose?
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 95
  1. #41 Re: Springs loose?
    heads off the engine vet. one valve is taller. who knows why.
  2. #42 Re: Springs loose?
    Right, I see that and agree on pics of the other side of the head. Looks like a bent valve on the one that's stuck partially open on the one that's shorter and neither rocker bolts look like they are tight.
  3. #43 Re: Springs loose?
    Enfield, CT
    I'm just surprised you didn't swallow a valve.
    Sent from my LG G3
  4. #44 Re: Springs loose?
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by 98bleedingaholevet View Post
    I loosened the rocker bolts thats why they are loose...
    Quote Originally Posted by HighOctaneRacing View Post
    Sent from my LG G3
    Me too lol
  5. #45 Re: Springs loose?
    GXP Level Member
    Mar 2015
    Tomball
    Did you find the end of the valve? We need carnage pics.
    Jeff
  6. #46 Re: Springs loose?
    Banned
    Jan 2013
    maryland
    Ok guys got back to the car and whew... That valve is done:
    ... But my pistons are fine? I Dont get it.. bottom end is fine.. And no issues car was running with no issues before i did the front head gasket so it definitely needs a new valve but do you think i can resuse this head? They are stg 3 ported lol Also i pulled the rear head just for clarity and those heads are fine with no issues...im stumped...
  7. #47 Re: Springs loose?
    i called that one, busted stem.
    it looks like the bottom of the valve bounced around int hat head some, its kind beat up looking.
    wheres the bottom of the valve?
  8. #48 Re: Springs loose?
    Apr 2015
    Columbus, OH
    Wow, carnage indeed. That valve was definitely bouncing around in there for awhile. How is it possible it was running "with no issues"? You had to have heard that valve slamming around in there, and you definitely didn't have any spark in that cylinder.
    I would really be interested in a picture of that piston. Will be a miracle if its in good shape. I wouldn't run that head, no way. You would have to clean that combustion chamber up, probably have new seats pressed in and by the time it's smoothed out its gonna be more than a few cc's smaller than the other chambers.
    Top Swapped 01 Imp
  9. #49 Re: Springs loose?
    Banned
    Jan 2013
    maryland
    I can take a picture of the piston but it was fine with no issues.. Yea.. I figured that..sad face.... No way i can use the head...my stock head will go to the machine shop and thats that... Welp found the issue at least i can still use my springs
  10. #50 Re: Springs loose?
    we need the full pic here. the valve bottom, and the piston and cylinder please. the way that head looks the piston top has to match it.
    or is the valve bottom gone 100%? like in your mufflers now lol
  11. #51 Re: Springs loose?
    GXP Level Member
    Mar 2015
    Tomball
    ^^^ for sure there is no way that piston escaped unscathed. Man that sucks.
    Jeff
  12. #52 Re: Springs loose?
    Banned
    Jan 2013
    maryland
    Yeah cuz i have the xpz cam in..i gotta wait for the machine shop to finish the head which will take another week
  13. #53 Re: Springs loose?
    ported heads demolished id assume or think those can be saved by a good shop?
    let me guess baby pulley and you werent on e85, and you were running pump gas with the old xp tune on the xpz cam?
  14. #54 Re: Springs loose?
    Buffalo
    Quote Originally Posted by RickyBobby03 View Post
    Horrible looking valve seals. And how did you manage to break a valve ? 2nd , how did you manage to break a valve and NOT notice ? Geez man that sucks. I feel bad for ya - hope there isn't any damge
    Putting new seals on , I like to use a deep 10mm socket and tap down the seals until they seat.
    I would check the rear head as well
    edit - I just re read your post. You already pulled the head and the valve hasn't fallen out yet? Now I'm confused
    still confused how it continued to run with out any damage to the cylinder. Where is the rest of the valve ?
  15. #55 Re: Springs loose?
    GXP Level Member
    Mar 2015
    Tomball
    Those are stage 3 porting with the no blending around the valve guide?
    Jeff
  16. #56 Re: Springs loose?
    Jan 2014
    AR
    Sometimes ya gotta give up on finding the truth but like I always say: if it quacks and waddles, its usually a duck.
    Wonder if those punked out heads had back-cut valves, stem looks tiny and yep that valve head could be smithereens. I would not want to use anything over, too many burrs on everything that could cause preignition.
  17. #57 Re: Springs loose?
    Quote Originally Posted by jayroca View Post
    You may want to get your hearing, feeling and eyes checked.
    That head is effed up beyond help. That was making one hell of a racket because you were running on 5 cylinders with the valve head bonking around in the cylinder for what appears to be a very long time. Everyone in a car near you heard it, felt it, saw the unburned crap coming out of the cylinder. FYI, now I'm thinking you are deaf, dumb and blind.
    Nope, they will tell him to start over. Know the funny thing... he was following your "no ic" advice. Damn...we should consider this your fault and that would make two engines in two months... lol
    Anyone that has ever worked on an engine knows that piston and cylinder are fubared. Hence no picture. He "was just gonna replace a used head gasket" for no apparent reason.
    I call BS from the beginning. Own up to it Jay.. because right now we all think you are a deaf, dumb, blind lyin mofo.
  18. #58 Re: Springs loose?
    Banned
    Jan 2013
    maryland
    Lol . Well happy 4th to u...you got lot of talk and b**tching over for a question that i ask and got answer to....yes my piston is fine..nope its done .. My bad yes my head is f**ked .. Im not hm to take a pic im enjoying my time with my kids and hitting cookouts.. Jeez first thing on my mind isnt taking pics to prove to Billy whats goin on.. Lol thanks guys for all the help though be replacing the head next week lol lmao huh man..
  19. #59 Re: Springs loose?
    Nov 2013
    Wisconsin!
    Lol. That's impressive. No way no how the piston is whole. I mean 3800s chip pistons when they have a bad day......no chance in hell that a valve bouncing around didn't explode it. And the only way you didn't hear or feel that happen is if you werent driving it....ever. Ray Charles could see that. AND he's blind. And DEAD!!
  20. #60 Re: Springs loose?
    GT Level Member ill12will8's Avatar
    DC/MD
    He drives his car hard with half ass tunes. Told him a few weeks ago he was gonna blow another motor. But he won't leave the platform alone. Can't tell him nothing either
  1. What needs done to remove Lowering Springs and go back to stock springs?
    By NotEnoughGPs in forum Brakes/Suspension/Chassis
    Last Post: 05-19-2015, 09:49 PM
  2. something is loose
    By eyelobes in forum General Grand Prix Discussion
    Last Post: 10-17-2014, 11:14 PM
  3. Loose wire
    By Charles20212 in forum General Grand Prix Discussion
    Last Post: 10-15-2014, 11:10 AM
  4. Replies: 39
    Last Post: 02-04-2013, 10:42 AM
  5. something seems loose
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 03-08-2008, 01:55 PM
