Thread: Oil cap
Results 1 to 9 of 9
  1. #1 Oil cap
    Aug 2012
    Calgary AB
    Hi All
    I am just seeing if when you take off the oil cap with the motor is running. What should happens
    to the motor? For me the motor dies.
    What I did,ported intake, ssic, ported sc, to a 1999 n* TB
    Did a smoke test blocked off the TB. Just had I small leak at TB. Fixed.
    So now I take off the oil cap and its under pressure and smoke would come out of the oil cap.
    I put my hand over it and it builds up pressure.
    Car runs good @ wot locks in @ -4.7
    I think that's all. Help
    Ty
    Oneredi
  2. #2 Re: Oil cap
    your ic is likely blocking off the pcv, thats the only thing that makes the oil cap suck in.
    give this a read. http://www.grandprixforums.net/threa...cover-breather!
  3. #3 Re: Oil cap
    GXP Level Member
    Mar 2015
    Tomball
    But he is saying it is blowing out, not sucking in.
  4. #4 Re: Oil cap
    sounds like its sucking in to me, either way the ic is likely the issue. as he said it stalls cap off too.
  5. #5 Re: Oil cap
    Donating Users timboku's Avatar
    Montgomery, IL
    Pics of how you ran your vac lines to the nstar? The ssic utilize stock pcv functions so as long as the front and rear ports are not blocked, vac lines routed correctly, and you have a pcv with the oring, you should be good.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  6. #6 Re: Oil cap
    Aug 2012
    Calgary AB
    So with the motor running take oil cap off motor stalls, dies.
    When I did the smoke test TB covered take oil cap off smoke will come out.
  7. #7 Re: Oil cap
    Aug 2012
    Calgary AB
    So with the motor take oil cap off motor stalls, dies.
  8. #8 Re: Oil cap
    GXP Level Member
    Mar 2015
    Tomball
    PCV in backwards and improper sealing of PCV? If it's building positive pressure when you have your hand over the oil tower (whatever it is called), and vapor coming out indicates it's not sucking in right?
    just trying to understand it not arguing the fact. The IC and N* TB I knk nothing about so that's throwing me.
    Jeff
  9. #9 Re: Oil cap
    hos is the ic installed? gaskets or rtv? if its all rtv id take it off make sure the pcv holes are clear and start over.
