Thread: Pulled fuel injectors for cleanup, car won't start?
Results 1 to 20 of 21
  1. #1 Pulled fuel injectors for cleanup, car won't start?
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    So I had an oil leak, and I pulled the fuel rail and injectors to get it cleaned up. I put it all back together, reconnected all the wires and everything, bled the fuel rail, and went to start it up... and nothing. It cranks for a while, tries to fire, dies, and makes this weird squeak sound. Any ideas on what may have went wrong?
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  2. #2 Re: Pulled fuel injectors for cleanup, car won't start?
    double check all the plugs. im thinking the icm harness in the front of the engine is unhooked maybe.
  3. #3 Re: Pulled fuel injectors for cleanup, car won't start?
    Apr 2015
    Illinois
    Finally got it to start and run for a bit, but there was smoke everywhere, mostly from the exhaust, thick and white. Car was bouncing like crazy and it ran like ****. Any chance it could just be really, really flooded?
  4. #4 Re: Pulled fuel injectors for cleanup, car won't start?
    if you hosed the engine down with the injector holes open, yeah it was flooded alright. lol
  5. #5 Re: Pulled fuel injectors for cleanup, car won't start?
    Apr 2015
    Illinois
    No, but I forgot to bleed the rail before I pulled it, so it poured quite a bit of gas straight into the intake, lol. Any easy fix, or do I just let it run out? Or am I in for a big job?
  6. #6 Re: Pulled fuel injectors for cleanup, car won't start?
    Quote Originally Posted by PaintChips97 View Post
    Where was the oil leaking from? What did you use to clean it up with? What did you do to fix the leak?
  7. #7 Re: Pulled fuel injectors for cleanup, car won't start?
    Apr 2015
    Illinois
    Valve cover gaskets weren't torqued down enough, leaked onto the manifold, I figured I'd clean it up right. I just used water and degreaser, and torqued the cover down right
  8. #8 Re: Pulled fuel injectors for cleanup, car won't start?
    with open injector holes? those holes go right ti the cylinder. so you filled them with some water and crap. spark plugs wet with water dont fire at all lol
  9. #9 Re: Pulled fuel injectors for cleanup, car won't start?
    let it run till it runs with out smoking and clears up.
    if it dont clear up try new plugs. they may be fouled.
    how did gas get in the intake? where did it leak from?
  10. #10 Re: Pulled fuel injectors for cleanup, car won't start?
    Apr 2015
    Illinois
    Well, I covered them somewhat, but not enough, lol. I'm just gonna get new plugs to be safe, and run it til it clears up. That should do it, right?
  11. #11 Re: Pulled fuel injectors for cleanup, car won't start?
    Apr 2015
    Illinois
    Okay, I'll give it a go in the morning. It leaked from the rail when I pulled it
  12. #12 Re: Pulled fuel injectors for cleanup, car won't start?
    You didn't get any water or degreaser into the injector holes did you?
    And what Scott said^
  13. #13 Re: Pulled fuel injectors for cleanup, car won't start?
    if its running, let it run. it should clear up.
    when you first started to crank it, did it ever stop cranking over? if it got hydro locked thats not good at all for the rod bearings.
  14. #14 Re: Pulled fuel injectors for cleanup, car won't start?
    You might want to do an oil change btw.
  15. #15 Re: Pulled fuel injectors for cleanup, car won't start?
    Feb 2013
    37.295091, -121.930053
    rod bearings are really fun to replace NOT
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  16. #16 Re: Pulled fuel injectors for cleanup, car won't start?
    Apr 2015
    Illinois
    No, it'd crank over fine, but once it'd start, it'd die out almost immediately. Probably starting on 2 or 3 plugs firing. It finally stayed running, but like I said, it ran like crap
  17. #17 Re: Pulled fuel injectors for cleanup, car won't start?
    thats good. all the same the plugs got wet with water likely.
    you can pull the plugs and see if they are wet. with gas now too. crank the engine plugs out a bit to dry it out. then put the plugs back in.
  18. #18 Re: Pulled fuel injectors for cleanup, car won't start?
    SWPA
    Pull the plugs. Crank it over a few times. Reinstall plugs.
  19. #19 Re: Pulled fuel injectors for cleanup, car won't start?
    Apr 2015
    Illinois
    The mosquitoes are out and the sun isn't, so I'll get at it in the morning. Thank you guys! Really scared me
  20. #20 Re: Pulled fuel injectors for cleanup, car won't start?
    **** mosquitoes.
  1. Car cranks but no start. Fuel injectors not releasing gas
    By Shiftingshaddow in forum General Tech Discussion
    Last Post: 04-20-2016, 06:58 AM
  2. WTB: fuel line from injectors to fuel filter for 99GTP coupe
    By Swole in forum Wanted To Buy - Parts
    Last Post: 08-25-2014, 02:36 PM
  3. 98 GTP Will Not Start, ECM not initalizing fuel pump or Injectors?
    By gzibell in forum General Grand Prix Discussion
    Last Post: 08-01-2014, 11:08 PM
