Thread: installing roller rockers have lash (loose) help?
Results 1 to 20 of 21
  1. #1 installing roller rockers have lash (loose) help?
    Aug 2014
    albany ny
    Hello was wondering if someone could help!!
    I was installing a slp roller rocker kit yesterday that I purchased a while ago off of a member, and while I was tightening down the rockers I realized they had a lot of lash (very loose) It was way too loose for me to comfortably put back together like that. The only thing I can think is maybe the push rods are not long enough, but at the same time don't see how that's possible bc the kit should have the correct size push rods. The push rods are roughly a quarter inch longer than the stock ones, which does seem to be about the proper length so I dont know if maybe Im doing something wrong installing these or what is going on with it. If any of you have any ideas or advice that would be greatly appreciated.
  2. #2 Re: installing roller rockers have lash (loose) help?
    lifters lost pressure, it will sound like crap when first fired up, let it idle for a while they will stop clapping. same thing happened when i put rockers on my car. all tq'ed down, yet they move up and down a little bit.
  3. #3 Re: installing roller rockers have lash (loose) help?
    Aug 2014
    albany ny
    Quote Originally Posted by ScottyBDoggs View Post
    I did not know that so I put the stock ones back on, which were tight when I put them back on, would the stock rockers still be tight if the lifters collapsed? I'm not sure bc I never fired it up with the slp rockers bc of how loose it was and not knowing.
  4. #4 Re: installing roller rockers have lash (loose) help?
    Quote Originally Posted by matthew83 View Post
    i made a phone call. was told to fire it up and enjoy. sucks you took em back off, better safe than sorry i guess.
    mine are 1.95 rockers, so i had a washer for a shim under the pedestal and longer push rods. had the play got nervous for sure. all worked out fine tho. both times.
  5. #5 Re: installing roller rockers have lash (loose) help?
    Buffalo
    Yah. Same here. I posted a video of it. I never would have 2nd guessed myself if I didn't have any variables ex custom heads and valves.
  6. #6 Re: installing roller rockers have lash (loose) help?
    Apr 2015
    Columbus, OH
    Mine was opposite.I put in new lifters and when I tightened them my valves opened when they should of been shut. Nervous for the first few minutes after I started it, bit it did get quiet and has been since.
    Top Swapped 01 Imp
  7. #7 Re: installing roller rockers have lash (loose) help?
    Quote Originally Posted by bandook View Post
    this is how the rockers went on my new set up. lifters still had pressure pushed the valves open. you can just turn the engine so each piston it tdc then tq em if you like. what i did this time cause its easy with the engine out of the car.
    you can see how they are all up and down in this pic. only two were not tight this time around installing them.
  8. #8 Re: installing roller rockers have lash (loose) help?
    Buffalo
    SLP and Yella Terra are pretty much identical
    http://intense-racing.com/Merchant2/..._Code=3800_HCV
    theyshould have come with the longer rods.
    My Harland Sharp 1.9s had longer rods as well
    the 1.9 MODIFIED stock rockers didn't need them
  9. #9 Re: installing roller rockers have lash (loose) help?
    Not to prove Bob wrong on the Harlands..but I've yet to see a set of Harlands come with different length rods.
    I've only had something like 10 sets..
  10. #10 Re: installing roller rockers have lash (loose) help?
    Oct 2011
    Toledo, OH
    Should you buy longer rods for them anyway?
    7"
  11. #11 Re: installing roller rockers have lash (loose) help?
    Aug 2014
    albany ny
    Ok thanks everyone going to put them on
  12. #12 Re: installing roller rockers have lash (loose) help?
    Buffalo
    No Bill you're correct - but it was OR rods that came with them (at least for me unless Intense told me to buy them on tb side) So 2 out of 3 had the longer rods or at least sold that way from the vendors.
    Its been soo long lmao
  13. #13 Re: installing roller rockers have lash (loose) help?
    Buffalo
    No. I checked. My HS had oil restricted rods.
    The Yella terra are sold with longer rods as per the vendor site.
    I also heard the SLP are identical as the Yella terras. So I would think they need longer rods as well
  14. #14 Re: installing roller rockers have lash (loose) help?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Crazyguy03 View Post
    Sorry to hijack this thread, but does that mean the HS still need aftermarket push rods? Or are factory ones Oil Restricted?
  15. #15 Re: installing roller rockers have lash (loose) help?
    Buffalo
    No. OR rods are aftermarket. You use them to the keep the lifters "pumped up" at the higher RPMs you would be at when adjusting your tune for high ratio rockers
  16. #16 Re: installing roller rockers have lash (loose) help?
    Oct 2011
    Toledo, OH
    So it would be recommended to get some at least? Unlikely that I'll raise my shift points though.
  17. #17 Re: installing roller rockers have lash (loose) help?
    Buffalo
    Well it's my understanding the higher ratio rockers benefit from higher shift points
  18. #18 Re: installing roller rockers have lash (loose) help?
    Yes very much so, they actually provide the best performance at a certain rpm range. Same goes with a cam.
  19. #19 Re: installing roller rockers have lash (loose) help?
    Jan 2014
    AR
    In the department of useless info... us carb-era dudes would remove an intake manifold to do the most precise lifter preload adjustments, or visually confirm lifter condition during valvetrain setup. Lets you see or measure how far the plunger is down inside the lifter body. Non-adjustable valvetrain is kinda scary to me especially if I can't see the lifters.
  20. #20 Re: installing roller rockers have lash (loose) help?
    Enfield, CT
    So should I be getting OR push rods when I go to install my ER rockers?
