Thread: Baro. Sensor unhooked for over a year.. never noticed..?
Results 1 to 7 of 7
  1. #1 Baro. Sensor unhooked for over a year.. never noticed..?
    Jul 2014
    Belfast, me
    I'm feeling kinda stupid..
    To start this story I was checking my intake manifold for a gasket leak (have a evap. large leak code) and I was spraying my intake down with ether and I noticed there was a vacuum line going to the map sensor but nothing to the baro sensor so I hooked it all up took the neg. Cable off the battery and let it sit for 30 seconds or so and hooked it back up. Started the car and it ran great better then it has since I first got it. Idle sounded better and it felt like it had a little more power so I came into it a little and the car went into "limp mode" and I pulled over and popped the hood got out of the car and it stalled and wouldn't start for about 10 minutes so I used torque pro and looked up the code and it was a map sensor code and cam pos sensor.
    This car has been 2 steps forward and two steps back ever since I bought it...
    So my question is am I an idiot for not noticing this baro sensor not being hooked up? I don't see how I've never noticed it personally I've been all around the motor and never noticed it.
    This coming up weekend I'm buying a new cam pos sensor and trying that AGAIN and going to get a new baro sensor and put that in.
  2. #2 Re: Baro. Sensor unhooked for over a year.. never noticed..?
    Apr 2015
    Columbus, OH
    I'm a little cornfused. You have a map AND a baro sensor? Is this a genV thing? I thought they were the same thing? Are you talking about the boost solenoid?
    Top Swapped 01 Imp
  3. #3 Re: Baro. Sensor unhooked for over a year.. never noticed..?
    Dec 2010
    DMV
    Gen v has a map and a baro sensor
  4. #4 Re: Baro. Sensor unhooked for over a year.. never noticed..?
    hangover park IL
    not all, only the "high altitude" cars got em. cars sold in area's without large elevation changes are of the single MAP design that refrences baro before startup.
    remove the vacuum line that you incorrectly added to the barometric sensor. it is only meant to register ambient air density, and to do so while your driving up a mountain or down one. that way to keep the cat/emissions happy its able to adjust fueling for less/more dense air. a single map car would need to be shutoff and restarted or to exhibit very specific WOT criteria for it to "update" its baro measurement
    your MAP sensor is MANIFOLD AIR PRESSURE. and as its name imply's its to measure the air pressure inside the engine
    ~James~ Psychotic Gearhead
  5. #5 Re: Baro. Sensor unhooked for over a year.. never noticed..?
    Jul 2014
    Belfast, me
    So it being unhooked makes no difference on way or another.
  6. #6 Re: Baro. Sensor unhooked for over a year.. never noticed..?
    hangover park IL
    IT MUST NOT BE HOOKED UP.
    FROM GM IT IS NOT HOOKED UP
    IT IS TO SAMPLE OPEN AIR PRESSURE aka BAROMETRIC pressure
  7. #7 Re: Baro. Sensor unhooked for over a year.. never noticed..?
    Jul 2014
    Belfast, me
    K gotcha thanks!
  1. Baro sensor crossover
    By J57ltr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2015, 03:28 PM
  2. L32 map/baro sencor
    By xBlacKxGTPx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2012, 05:04 PM
  3. Year range for MAF sensor?
    By Phurst in forum General Tech Discussion
    Last Post: 08-06-2010, 03:58 PM
  4. Map baro corallation dtc please help
    By imjustanobody34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2010, 08:13 AM
  5. Map/baro help!!!
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2008, 11:53 AM
