Quote Originally Posted by kewGTP View Post
Alright, so in short form I want to run 12's in the 1/4 (don't care if its high or low 12's), still be my daily driver, and be reliable.
My first thought is to go for the main mods (yes supporting mods will be done as well)
1:9.1 Rockers
S2 IC from ZZP
ZZP Stainless Headers
However, I keep thinking I will kick myself if I don't go the cam route instead
XP Cam
S2 IC from ZZP
So my question is, will a rocker/IC setup possibly get my into the 12's? I don't know that I want to pay a lot more in install work to put in a cam.
You can get into the 12's with rockers/IC and drag radials if you can launch. Otherwise it'll be tough without a cam. Just depends on how low you can go pulley wise/ how much timing you can run. Safe bet is to cam it, E85, intercooler (if you still want to), and drag radials.
