Thread: Should i drop to a 3.0 on a Gen V or a 3.2?
Results 1 to 6 of 6
  1. #1 Should i drop to a 3.0 on a Gen V or a 3.2?
    Banned
    Jan 2013
    maryland
    My Mods:
    XPZ Cam w/Pushrods
    Stg 2 or 3 Heads w/130# Springs
    Ported Lim
    Gen V w/ 3.4 pulley
    N* LQ4
    Intake
    60# Injectors w/Fpr and Walboro Fuel Pump
    Zzp Tune for Mods
    I currently have NO KNOCK Would i be safe to run a 3.0 on the Gen V? Or try a 3.2? Im always scanning though.. Thanks!!!
  2. #2 Re: Should i drop to a 3.0 on a Gen V or a 3.2?
    Nov 2011
    NY
    So what will you do when you encounter KR? You can drop, but without the ability to change the tune, you'll pulley back up with Knock. So if you have no knock, I'd say enjoy the ride!
  3. #3 Re: Should i drop to a 3.0 on a Gen V or a 3.2?
    Buffalo
    Pretty much sums it up. Most throw on a small pulley and tune around it to make it work
  4. #4 Re: Should i drop to a 3.0 on a Gen V or a 3.2?
    gardner,mass
    zzp tunes are rich so you could probly get away with a 3.2 but with the mods a 3.0-3.1 is doable with a real tune. If your spending money on those mods get a real tune, you wont believe what your losing. With that being said gauge your pulley around being able to run like 17-18 * timing with 11.7-12:1 afr knock free.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  5. #5 Re: Should i drop to a 3.0 on a Gen V or a 3.2?
    Kemmerer, Wyoming
    pulleys are easy to resale, I would go down a little at a time and resale the one you know you don't need and wont use anymore. Its always better to have more pulleys than less.
  6. #6 Re: Should i drop to a 3.0 on a Gen V or a 3.2?
    Banned
    Jan 2013
    maryland
    Cool i will try and 3.2... 3.0 to max out on pump gas... If im knock free... 2.8 for the grand finale... On e85 and a dyno tune
  1. oil pan drop
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 10:22 AM
  2. MPG Drop
    By 2k6GT in forum General Tech Discussion
    Last Post: 08-14-2009, 11:56 PM
