Thread: I need advice for a replacement engine
Results 1 to 6 of 6
  1. #1 I need advice for a replacement engine
    Sep 2013
    Massachusetts north shore
    I just blew my engine and I need a good replacement all of the l67 are 100k plus mileage and are around $400 last year there were more options at lower prices but not now
    My other option is to drop in a 2007 n/a block and swap my heads I found one with 50k and $300 but I don't want to loose strength in the rods and pistons. is the l26 stronger than the l36 or l67 I have read that the l67 are l36 rods are stronger
    And to help with kr I am planning on running a thicker head gasket
  2. #2 Re: I need advice for a replacement engine
    Are you making more than 500 whp? If not the bottom end wont matter. And just use normal head gaskets. Run a "cold air intake", 180* tstat and maybe 1 step colder plugs.
  3. #3 Re: I need advice for a replacement engine
    And you make how much power??
    Anything under 400, run whatever motor you can find.
    I never hear of anyone snapping a rod or cracking one or anything like that. Either it knocks itself to death or the piston explodes.
  4. #4 Re: I need advice for a replacement engine
    There is a thread on the Fiero Forums where a dude broke a rod in his turbo car while cruising down the interstate. He was making north of 500 whp though.
  5. #5 Re: I need advice for a replacement engine
    Sep 2013
    It blew on the dyno while tuning it 250hp 300 ftlb the number pissed me off more than the engine spinning a crank bearing but after the first two runs I made some changes and the last run it all let go I usually don't go over 5k 5500 rpm but the guy running the dyno hit 6250 or what ever I had set for red line
    Mods are gen v , 3.0 pulley, intercooled, 1.9yt, ls7 lifters , Ported t.b. intake s/c , sd headers full exhaust , 42.5 racetronix etc etc ... I just can't have this happen again and I am looking for something with around 50k that's cheap and strong
  6. #6 Re: I need advice for a replacement engine
    Sep 2013
    I have read that the l32 l26 engines uses powder metal rods and coated skirts but some have shattered the rods is this a common problem I understand that with the rigidity of powder metal rods they break instead of bending or just flexing like cast but is this really stronger?
  1. Replacement springs advice for 05 GTP
    By dbane in forum Brakes/Suspension/Chassis
    Last Post: 03-29-2015, 05:38 PM
  2. Replacement time looking for advice
    By TeacherCreature in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2013, 06:59 AM
  3. Advice on lifter replacement
    By goldgp in forum General Tech Discussion
    Last Post: 02-12-2011, 08:51 PM
  4. Advice on gasket replacement
    By ajnelson4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2010, 12:46 PM
  5. Lawngoose's Replacement Engine Advice/Question Thread
    By Lawngoose in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2010, 10:55 PM
