I just got my aem uego wideband kit, and I was wondering where everyone is getting their power from for the gauge? Also where are u grounding it to? I have an 04 comp g.
Thanks
Thanks
I just picked a 10amp fuse that see's power when the key is on.
I use a add-a-ciccut dealio from the parts store, either pick a radio fuse or even an IGN fuse. I just ground to the body where the steering column bolts too.
Where did u run the wire from the sensor through the firewall to the gauge?
There's a spot in the drivers footwell you can run wiring through, there's a big square grommet under there. When I had my autometer boost/trans temp guages, that's where I ran the wires and tubing through, and the FP rewire wire as well. I think there's another spot on the drivers side above the throttle pedal, little harder to get to iirc.
Thank u
Grommets and drill bitsDunno how different yours is to my impala, but I couldn't find a good spot so I just drilled through the passenger foot well.
There's also a spot under the passenger side carpet/footwell... Pop grommet to get the head of the WB sensor connector through, put back once wire is through. Done! : )
