Thread: Wiring harness problem need info please help
Results 1 to 9 of 9
  1. #1 Wiring harness problem need info please help
    GT Level Member revin24's Avatar
    Apr 2013
    Flint, Mi
    I pulled the motor out of my car 2 yes ago and we ripped off some sensor wires I went to the junkyard to get replacement plugs but the colors are different this is the section of harness that goes behind the alternator goes down to the knock sensor, the rack, oil press, vehicle speed sensor and possibly another sensor I overlooked because I have 2 wires in that section of harness that I don't know where they go it's a 2000 gtp if anyone can help me figure out what colors go to what plugs and possibly what plug to what sensor I'm missing i don't know what else to do here I haven't been able to find a wiring diagram with the wire colors on it I seriously miss my car and want to drive it soon
  2. #2 Re: Wiring harness problem need info please help
    A picture of the harness in that area would be super helpful.
    Coming down that area you have:
    Small gray plug two wires (VSS on tailshaft of trans)
    Oval large green plug two wires (Oil pressure sensor)
    Black connector long one wire (rear knock sensor, connects to pigtail that stays on rear knock sensor)
    Square black connector four wires (downstream O2 and most likely your issue)
  3. #3 Re: Wiring harness problem need info please help
    Apr 2013
    Flint, Mi
    I will Take a picture of it later when I get up but I only have two wires extra instead of 4 though which has me puzzled
  4. #4 Re: Wiring harness problem need info please help
    Apr 2013
    Flint, Mi
    Is it possibly the crank sensor? I know the cam sensor runs on the other side by the ignition coils
    I will have to re evaluate the situation today cuz rear o2 sensor dose seem possible after some thought I haven't seen those wires or plug in a while
  5. #5 Re: Wiring harness problem need info please help
    No, it's only one of the sensors I've mentioned in my post.
    Not to sound cocky, but I've named connectors on a harness too many times and am confident about this.
  6. #6 Re: Wiring harness problem need info please help
    Apr 2013
    Flint, Mi
    I think I figured it out accept I don't know where the power steering pressure switch wires go I don't have two more wires on that section of harness
  7. #7 Re: Wiring harness problem need info please help
    Apr 2013
    Flint, Mi
    Alright I've figured it out I had the power steering switch running to the passenger side and the plug it goes to is on the transmission next to the shift switches so I have it all figured out now thanks Bill u were rite I had forgotten about the rear o2 sensor since it doesn't have it anymore
  8. #8 Re: Wiring harness problem need info please help
    There is no power steering switch though. Only the plug for the magnasteer, which... shouldn't even reach that far over.
    Glad you figured it out.
  9. #9 Re: Wiring harness problem need info please help
    Apr 2013
    Flint, Mi
    It didn't that was part of my confusion apparently after some looking around on the net that is some sort of pressure switch I don't know y it would be nessisary but apparently that's what it's for
  1. Wiring Harness
    By Dr Cedric in forum Visual/Body Modifications
    Last Post: 08-17-2014, 12:17 PM
  2. WTB: LQ4 w/ Wiring Harness!
    By sdavis11b in forum Wanted To Buy - Parts
    Last Post: 08-29-2013, 05:05 PM
  3. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  4. Wiring harness
    By Dedlydragoness in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2009, 04:51 PM
  5. zzp wiring harness
    By TheOtherNick in forum Audio, Security & Visual Electronics
    Last Post: 11-03-2008, 02:47 PM
