Thread: 2 issues, 5 codes. need help please
Results 1 to 3 of 3
  1. #1 2 issues, 5 codes. need help please
    Florida
    Issue 1 has been here for the long run. I've been thru 2 different o2 sensors and 2 zzp extensions since I installed my SD headers last year. These codes will not go away and it's affecting my gas mileage. P0035, p0036, p0141 and I think a code p0135 Idk I'd have to check again. It's all involving the front o2 and Idk why. Something said low voltage bank 1 blah blah. Anyone had this issue or could give me a possibility? Issue 2 is a random misfire code. Upon startup car idles pretty rough and after awhile it evens out. The misfire does not affect drive ability at all only idling unless I have the ac on. Plugs are fresh,coils done just over a year ago but I'm thinking maybe my wires? Injectors are firing and compression is good. Any ideas?
  2. #2 Re: 2 issues, 5 codes. need help please
    Jan 2014
    Milan, IL
    kinda a long shot. but my I had them same issue with an 02 extension melting on my ad headers. blew an ignition fuse under the hood. then my boost bypass valve failed. so make sure you bypass valve is open at idle and that the ignition fuse under the hood isn't blown
  3. #3 Re: 2 issues, 5 codes. need help please
    Florida
    Ok ill check. Thanks
  1. a few codes i need help with!
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2013, 07:53 AM
  2. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  3. NEW MEMBER HELP PLEASE!! DCT codes and driving issues.
    By silver86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2012, 10:05 PM
  4. PID Codes?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 10-20-2010, 07:41 PM
  5. Bad idle and RPM issues not to forget codes P0303, P0341, AND P0300
    By jessiinicole in forum Off Topic Discussion
    Last Post: 03-08-2010, 02:27 PM
