Thread: arp head studs?
Results 1 to 20 of 22
  1. #1 arp head studs?
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    does anyone know where to get head studs? are they worth it?
    '01 GTP mods: K&N intake, autolite 104's, drilled 180*, !u-bend, !EGR, ported s/c, polished heads and TB and a LOT more whine
    '99 firebird mods (1 of 6): LS1 swap, custom exhaust, LS6 IM, RA intake, and a few suspension parts
  2. #2 Re: arp head studs?
    Aug 2008
    Flushing/Flint, MI
    intense-racing.com, zzperformance.com
    And yes every penny
  3. #3 Re: arp head studs?
    very worth it. easier to put the heads on, better load distribution, you can crank them down more, etc.
    i have my stock heads at ~90 ft/lbs with them running felpros non-intercooled. they have worked great so far.
  4. #4 Re: arp head studs?
    Jan 2009
    Grand Rapids, MI
    ARP HEAD STUDS are worth the money. I've been runing them with felpro gaskets non intercooled and seeing 16 lbs of boost with my setup.
    XP~GEN V~SSIC~2.8~HEADERS~P&P HEADS~78mm TB~SLP LOUDMOUTH
    318 whp, pump 92 octane, 18" wheels
    Before Gen V
  5. #5 Re: arp head studs?
    Aug 2008
    denver, co
    well, ordered from arp. any recomendations on these for install?
  6. #6 Re: arp head studs?
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    Dont overcrank the studs when you install them, follow the factory torque specs for the heads.
    Studs make things stronger, I used nothing but ARP fasteners in every engine ive ever built.
  7. #7 Re: arp head studs?
    Aug 2008
    60118 NE Illinois
    Threadlocker is good to use when installing these as well. they wont walk but it eliminated the chance that it can.
  8. #8 Re: arp head studs?
    use TEFLON PASTE to install them. if you use tape, youre going to get leaks. goober them up nice, thread them in hand tight and clean up the excess that bleeds out. put the heads on within an hour or so, no longer. torque the heads down in like 30-60-75 ft lbs in that order or something close to those numbers. i have mine torqued at 90 ft lbs and they are good so far.
    do whatever you want, but do it the right way.
  9. #9 Re: arp head studs?
    Aug 2008
    Flushing/Flint, MI
    if you use paste you need to installthe heads shortly after you put the studs in if the paste dries and then you torque you will break the seal and leak. Or use tape and just put it on thick. people will argue this either way. You do need to use more than stock torque spec. Torque spec will depend if you use arp mily lube or oil to torque.
  10. #10 Re: arp head studs?
    Aug 2008
    60118 NE Illinois
    Teflon tape is not good for head studs/bolts. a piece of that tape comes off and gets in an oil passage, gets back to the pump and blows out the oil pump.
    Never use tape on internal threads.
  11. #11 Re: arp head studs?
    Aug 2008
    Flushing/Flint, MI
    funny ZZP seems to think the opposite
    "Teflon tape required for threads going into the block to prevent coolant leaks. Do not use a paste to seal these!" --zzp
    but what do they know they barely work on 3800s
  12. #12 Re: arp head studs?
    yeah, its argueable, but i used paste and it worked well for me.
  13. #13 Re: arp head studs?
    Barksdale AFB, LA
    Teflon tape is too fragile to screw anything up. It tears if you look at it wrong.
    2009 Subaru Impreza WRX STI
  14. #14 Re: arp head studs?
    Aug 2008
    denver, co
    alright im stupid and am going to use my own thread....but where is the topic with all the tq specs?
  15. #15 Re: arp head studs?
    I live here. UR LOSN's Avatar
    Rockford, IL
    follow the specs given by ARP. I have mine with a final torque spec of 90ft lbs.....
    I went 35, 75, 90.... using the same torque sequence as factory.......
  16. #16 Re: arp head studs?
    Aug 2008
    denver, co
    i know that lol i need tq specs for everything else! and my chiltons for children does not help...
  17. #17 Re: arp head studs?
    TDCRacing
    Guest
    Why not just use RTV?
  18. #18 Re: arp head studs?
    Oklahoma
    I have most of the torque specs on my PC, I just havent had the time to get them in a document form and add them to my documents project.
  19. #19 Re: arp head studs?
    Aug 2008
    denver, co
    well you suck! step it up! but anywho! what is the tq and pattern for the s/c snout?
  20. #20 Re: arp head studs?
    Oklahoma
    Well to be honest, Ive never seen any torque specs for that. Since GM didnt do any work or repair the superchargers, I dont think there were any published specs. You may be able to go to Eatons website and find some, but Ive never checked to see if they were there.
  1. Using Studs such as ARP
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2015, 08:43 AM
  2. wheel studs
    By ibanez0110 in forum General Tech Discussion
    Last Post: 11-10-2008, 07:52 AM
  3. Wheel Studs....
    By Vegas~Blown in forum Brakes/Suspension/Chassis
    Last Post: 08-30-2008, 12:47 PM
  4. Who is running ARP head studs???
    By Trannyman95 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 03:29 AM
  5. Studs
    By wrfdff4 in forum Tires & Wheels
    Last Post: 03-31-2008, 11:16 PM
