Thread: Phenolic IC ISSUES..please help. Sucking in oil cap.
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: Phenolic IC ISSUES..please help. Sucking in oil cap.
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Thank you for the help guys! I now understand that it must be before the throttle plate and after the maf.
    Is this the same as drilling a port on the bottom on my throttle body and connecting to there instead?
    Say I fix my plugged front pcv later on sometime and leave this line hooked up. Are there any ill effects?
    I am lq4 maf. Stock maf is just there cut in half to seal the hole up (bought like this)
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  2. #22 Re: Phenolic IC ISSUES..please help. Sucking in oil cap.
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by PWNED View Post
    This is exactly what I was thinking but I was told other wise. Well I was half right I suppose (as I wanted to put it around my iat area)(before the maf) If you can take a look at this link. Both are acceptable? One better than the other?
    http://www.grandprixforums.net/threa...16#post1347516
    Side note....do you have a sealed oil fill cap or is that partially vented with a port on the side? Which you can find at local auto parts stores. Curious.
    I have one of these and it's sealed as far as letting outside air in.
    http://www.spectreperformance.com/ca...?cat=C00000244
    You want it after the maff, like Bill said it doesn't need to be NEW air coming in. It needs to be air already circulating like normal.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    By sseilmnop in forum How To Write-Ups/Tech Tips
    Last Post: 06-15-2017, 10:15 AM
  2. New K&N air filter making sucking noises.
    By Banse in forum General Grand Prix Discussion
    Last Post: 09-26-2013, 02:30 AM
  3. Intake not Sucking air gtp
    By kyleinkman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2011, 11:29 PM
  4. XP or Phenolic SS IC?
    Last Post: 06-30-2009, 01:19 PM
