I'm not sure there is a way to test them. I'm sure there is suppose to be a ertain amount of resistance between coils but i'm really not sure.
One other thing. If you can look at you're maf flow table as a graph veiw to make sure it does not look like a mountian...Largs peaks and valleys will also cause a car to jeark real bad if the peaks or valleys are high or low enough.
