Thread: fuel leak issue
Results 1 to 12 of 12
  1. #1 fuel leak issue
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    so today, i went out to the grand prix to go and get it detailed when for some reason i smelled gas, so i popped my hood and sniffed around, i pulled the engine cover off and sure enough, fule was dripping and nice puddle was forming and spilling down the supercharger , i was shocked and thankful that i caught it in time. what happens is there are 2 o-rings inside the fuel line that were completely corroded and done with, i called my GM dealer to see if it was possible to replace just the o-rings and they said nope "its an assembly" typical of GM lol. so i went through my o-ring service kit and found some good matches however VERY DIFFICULT TO SEAT PROPERLY. so i had to order the new fuel line from rail all the way back to the filter pretty terrible but not as terrible as say an engine fire, which GM claims is the front valve cover gasket that causes fires, its not clearly, if my lines leak im sure others do as well, also makes more sense why people leave the car off and come back and its on fire..... so ever so often check your lines at the rail, just to make sure you dont have a hazard waiting. i was lucky many others havent been
    COMP G
  2. #2 Re: fuel leak issue
    ohio
    I just had the exact same problem!!! Was planning on leaving on vaca in the morning too
  3. #3 Re: fuel leak issue
    GT Level Member BoostedComp's Avatar
    Youngstown
    mine did the same.. i just replaced the o-rings in the injectors.. the sell a set of 3 for like $2... unless im talkin about the wrong part that was leaking lol i hope you guys didnt get ripped off and i am wrong
  4. #4 Re: fuel leak issue
    SE Level Member ceelo's Avatar
    atlanta
    yes similar problem smelled gas while driveing opened hood gas running down the street. the leak was spraying from the fuel supply line quick fiting connection to the fuel rail. where. does o ring go over the male end of the fuelrail that goes into the fuel supply line or do the o rings go into the fuel supply line itself if so what size o ring where to suff the o ring in at. Or is it better to get a new fuel supply line . any ideal on a part number or how to take it off going back to the fuel filter. will pay any one in the atlanta area knowledgeable or capable of fixing issue even if u just tell me what to do and walk me through
  5. #5 Re: fuel leak issue
    Oct 2011
    San Jose, CA
    Any update on answers? having same problem at fuel line connection on top of supercharger, steady drip when running.
  6. #6 Re: fuel leak issue
    HUDSON
    I was behind a LeSabre that stank of fuel real bad, I thought it was my car, but I pulled into a station and lifted the hood of my car and smelled nor saw anything.
    I was aftraid my fuel line ruptured or somthing it was such a strong odor, not like a little wiff, but I think it had to be the BUICK infront of me because I have not smelled it since.
    I might change my o-rings just for the heck of it, to be on the safe side.
  7. #7 Re: fuel leak issue
    Oct 2011
    San Jose, CA
    Anyone have a "how-to link" to replace the o-rings in the fuel line connector on top of the supercharger? I searched but did not find replacing the o-rings in the connector above the supercharger.
  8. #8 Re: fuel leak issue
    Sep 2011
    Canada
    This is really good info to know. I'll be checking mine carefully now!
  9. #9 Re: fuel leak issue
    Oct 2011
    San Jose, CA
    okay i did find the "how to fix" this fuel line connector issue on this site, it is part of this: http://www.grandprixforums.net/injector_oring.php
    also see for the o-ring part number at O-Reily's
    http://www.grandprixforums.net/could...res-30008.html
    I called a GM dealer, they confirmed the o-rings are not available, have to buy entire fuel line. Got the o-rings, disconnectors and picks at O-Reily's per the mentioned threads and will try tonight.
  10. #10 Re: fuel leak issue
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    let us know how it goes --- it's a project that's on my list.
  11. #11 Re: fuel leak issue
    Sep 2011
    Canada
    I hope no one here gets the dissapointing surprise I did with my fuel injectors that I pulled out of my Camaro this summer:
  12. #12 Re: fuel leak issue
    Oct 2011
    San Jose, CA
    All, found the correct Viton o-rings for the fuel line quick disconnects on the supercharged Grand Prix. They are working fine so far, no leaks! Bought them at AutoZone, looks like O'Reily's also carries. Call ahead, may have to special order. Recommend also buying the mechanics pick set (dental like angled pick, very helpful with removal)
    Dorman #800-013 (2 @ 5/16 & 3/8)
    Dorman Products - 800-013
    Good replacement "how to" is found in this forum on this link:
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. Large EVAP LEAK and FUEL CAP LEAKING?????
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 12:55 PM
  4. diagnosing fuel leak
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 03:27 AM
  5. fuel leak
    Last Post: 08-18-2008, 03:40 PM
