Thread: Wire up L67 using an L26 engine harness?
Results 1 to 8 of 8
  1. #1 Wire up L67 using an L26 engine harness?
    Oct 2014
    United States
    Hi all. I'm looking to do an L67 swap into my project car and was wondering if an L26 harness can be used. I guess the big question is what kinds of mods will need to be done to the harness or what plug-and-play harnesses will I have to buy to make it work? Thanks for your help!
  2. #2 Re: Wire up L67 using an L26 engine harness?
    L67 harness should be cheaper.
    And easier.
    L26 isn't a supercharged harness from the factory, that'd be an L32.
  3. #3 Re: Wire up L67 using an L26 engine harness?
    Oct 2014
    United States
    Ok, thanks. I can get an almost mint L26 harness for super cheap so was wondering if it's usable with a few adapters or will the adapters end up costing too much? I have an old and worn 01 Park Avenue Ultra S/C engine harness I might could use but I don't trust it.
  4. #4 Re: Wire up L67 using an L26 engine harness?
    There might be a few carry overs, but plenty of the N/A stuff is just different enough not to work. Injectors, MAF, throttle body sensors don't exist like yours...MAP, etc.
  5. #5 Re: Wire up L67 using an L26 engine harness?
    It really depends on the years and models. If you are trying to put an 04+ harness into a 97-03 you'd have to swap the connector to the fuse box and a bunch of other items. If you are trying to use an L67 in an 04+ car then swap over the fuel rail/injectors to an L32 and almost all the rest works.
  6. #6 Re: Wire up L67 using an L26 engine harness?
    Oct 2014
    United States
    Thanks for the advice! Looks like I'd have to chop that harness all up to make it work so will probably just get an L67 harness.
  7. #7 Re: Wire up L67 using an L26 engine harness?
    Or get an L36 harness from the same year (as long as it's not 97) and you can easily change the map connector and add the BCS wiring/connector.
    I know it's easy.. cause I've done it a couple of times.
  8. #8 Re: Wire up L67 using an L26 engine harness?
    Oct 2014
    United States
    Thanks! I'll keep that in mind if I run across an L36 harness in great shape.
  1. wtb gtp engine wire harness and gen v to l67 tb adaptor.
    By timboku in forum Wanted To Buy - Parts
    Last Post: 04-13-2013, 12:30 AM
  2. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  3. 04 GTP PCM and Wire harness
    By sholdwick in forum General Tech Discussion
    Last Post: 08-15-2012, 06:13 AM
  4. Engine Wire Harness/Fuel line
    By Spartan GL in forum General Tech Discussion
    Last Post: 04-27-2011, 07:17 PM
  5. wire harness
    By BLKGP in forum Audio, Security & Visual Electronics
    Last Post: 10-25-2009, 11:38 AM
