I've been looking around at intercoolers for the GTP and there seems to be a fairly small selection and of the ones I see they look like someone just took a heater core and sandwiched it between the blower and lower intake. While this seems to work ok when they aren't leaking has anyone ever used something a little more efficient like the Laminova system. I'm pretty sure when I looked at the Cobalt that's what is being used in the setup used for them. This may have been preproduction versions, as I haven't looked at them since before their release.
So I was trying to clean out some crap in my garage and came across a 3 core setup that I was going to use back when I had my Tbird SC. I have all the parts except the end blocks. I still have the Acad drawings of the original end blocks and could make new ones. The only problem I see is that the cores are 12.5" long which would make the OAL about 14.5". The thickness is about 1.75" but should be closer to 2".
What are the LIM inlet dimensions for an L32?
Jeff
