Thread: IM SOOO CONFUSED!! MAF? FUEL PUMP? INJECTORS? whats next
Results 1 to 10 of 10
  1. #1 Re: IM SOOO CONFUSED!! MAF? FUEL PUMP? INJECTORS? whats next
    tach dropping to zero and random stalling is a crank sensor. it hardly ever sets the cel too. its a odd one.
  2. #2 Re: IM SOOO CONFUSED!! MAF? FUEL PUMP? INJECTORS? whats next
    GXP Level Member
    Mar 2015
    Tomball
    Although on my 97 PA my CEL flashes 4 times and the chime sounds 4 dings every 10 seconds and the car runs rough and surges, tach bouncing all over. The code came up as CPS circuit A error or something (I'll have to look it up). I replaced it (after having to have to have to tape the holes for the puller, weird huh?) and had the same problem. I was also getting a missfire #3 and since I had already replaced the plugs and wires about 6 months previously I ended up changing the coil pack. The car ran fine for about 35 miles and started doing it again. So I either have a defective CPS, or a break in the wiring for the CPS.
    Jeff
  1. 98 GTP Will Not Start, ECM not initalizing fuel pump or Injectors?
    By gzibell in forum General Grand Prix Discussion
    Last Post: 08-01-2014, 11:08 PM
  2. Replies: 8
    Last Post: 11-27-2013, 03:36 PM
  3. 42.5# Injectors, Flowjet pump, ZZP pump controller
    By StamperGTP in forum For Sale - Parts
    Last Post: 01-10-2012, 02:33 PM
