Thread: Turbo mounting with sd headers
Results 1 to 12 of 12
  1. #1 Turbo mounting with sd headers
    Aug 2013
    Kitimat, B.C.
    Anyone have any pics? Just trying to visualize.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Turbo mounting with sd headers
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    You can't use SD headers (or any) with a turbo unless it's custom piped.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  3. #3 Re: Turbo mounting with sd headers
    Feb 2009
    flintnasty MI
    Better off using stock manifolds.
  4. #4 Re: Turbo mounting with sd headers
    Kemmerer, Wyoming
    Depending on the turbo kit, power logs could be an option
  5. #5 Re: Turbo mounting with sd headers
    Aug 2013
    Kitimat, B.C.
    Crap well there goes that flicker of a dream.
  6. #6 Re: Turbo mounting with sd headers
    Feb 2013
    Missouri
    If $200 headers break your budget on a turbo build then a turbo might not be for you...
  7. #7 Re: Turbo mounting with sd headers
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Booba5185 View Post
    No I already have em on and a turbo on the shelf. I wanted to add the turbo as well, that's all.
  8. #8 Re: Turbo mounting with sd headers
    Feb 2013
    Missouri
    Even if you did add the turbo, it will make a lot more power with the correct tuning, but the transmission will eat itself and it'll cost a LOT to beef it up enough to take the power. Ironically the turbo is one of the cheaper things of a turbo set up (depending on the turbo, of course).
  9. #9 Re: Turbo mounting with sd headers
    Antioch, IL
    get 2 front headers, some tig fab work and it can happen.
    2009 Challenger SRT8
    Expert at being gay.
  10. #10 Re: Turbo mounting with sd headers
    hangover park IL
    i always thought the fiero folks wouldnt have any major problem besides cutting out a section of the storage floor with the turbo hanging off the DP flange
    ~James~ Psychotic Gearhead
  11. #11 Re: Turbo mounting with sd headers
    Aug 2013
    Kitimat, B.C.
    I had to cut out the rear trunk to be able to use the headers.
  12. #12 Re: Turbo mounting with sd headers
    Feb 2009
    flintnasty MI
    you can use headers... The stock manifolds will make more power / spool better.
  1. Mounting Kit
    By Mrc728 in forum Audio, Security & Visual Electronics
    Last Post: 11-12-2011, 01:36 PM
  2. Build your own turbo headers
    By Deimos in forum General Tech Discussion
    Last Post: 01-23-2011, 10:22 AM
  3. Mounting Kit??????
    By kingbrentdwyer in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2008, 02:08 AM
