Thread: Issue after intercooler install, car revs high then drops way low
Page 5 of 5 FirstFirst ... 345
Results 81 to 98 of 98
  1. #81 Re: Issue after intercooler install, car revs high then drops way low
    GXP Level Member
    Mar 2015
    Tomball
    So that connection goes inside the housing? Maybe that's where the leak is. That would explain how it leaks only when installed.
    g2g on plane heading home.
    Jeff
  2. #82 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    I tried it standing up like this, and laying down.
    02 Grand Prix GT Mods' Top Swapped Gen 3, Stage 2 IC, 3.0" MPS, 42# injectors, 1.8 Yella Terra roller rockers, Speed Daddy Headers, CAI, Self Tuned, 180 tstat, ram air hood, front/rear sway bars/and STB's AL 104's, 12' Dual Piston Break kit
  3. #83 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    OK I fixed the hoses going into the housing. They no longer go into it.
    Would it be a bad idea to install the core and not fill it with coolant and do a test drive?
  4. #84 Re: Issue after intercooler install, car revs high then drops way low
    GXP Level Member
    Mar 2015
    Tomball
    I think that will be fine. When the coolant is in it it is not under pressure like a radiator is and if it was then the vacuum on the core would cause greater force than without.
    Jeff
  5. #85 Re: Issue after intercooler install, car revs high then drops way low
    I drove mine for a few months with no coolant in it.
  6. #86 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    Installed the IC again today. Ran the car with no coolant in the IC. Low and behold WHITE SMOKE came out of the exhaust. What...how...grr.
    Both the coolant holes on the lim are blocked off. What is causing the coolant to get into the engine when the IC is installed but no coolant in the engine with just the sc on?
  7. #87 Re: Issue after intercooler install, car revs high then drops way low
    GXP Level Member
    Mar 2015
    Tomball
    So when you pull it down you don't touch the LIM right? Did you use Pipe dope or Teflon tape on the block offs for the TB? Do they sit below flush? when you removed the SC was there coolant where the TB is? My only thought is that with the IC in place the holes are lined up with the block off hex screws and if they are not below flush they may be pushing on the IC adapter and making it harder to seal but the block off seal screws would have to leak. Use your vacuum pump and one of the cups to pull a vacuum on each of the block offs. Other than that I'm out of ideas right now.
    Jeff
  8. #88 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    That is correct i do not mess with the lim, only clean the surface of it. i used teflon tape on the tap screws. They sit below flush. Ill pull the sc off tomorrow and look for any coolant. I havent noticed any coolant around the screws on my previous tries. I will pull a vacuum on each of them tomorrow as well.
    Anyone else with any other ideas feel free to chime in as well!
  9. #89 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    Where the bolt is pointing is the only place i saw a drop of coolant. Which is a pcv passage.
    You can see here how the npt plugs are recessed in. I did a vacuum test and they both held up.
  10. #90 Re: Issue after intercooler install, car revs high then drops way low
    GXP Level Member
    Mar 2015
    Tomball
    Man, I'm about as confused as a cow on AstroTurf. Now in your lower pic the PCV is the small hole that is half cut out closest to us in the pic (not the bypass) right? I've removed a bunch of M90's from GM cars but never really got into where everything is located. With that said then you would have to have a LiM leak near that port, but since it doesn't do it without the IC I don't get it, and can't make heads or tails of it.
    I've seen a missing PCV valve cause so much vacuum in the engine that it caused the crank seal to suck in and squeal on the crank journal. Opening the oil cap relieved the vacuum and placing a the PCV back in solved the problem. That was an NA series2 engine that had the UIM (composite) replaced after a backfire and the mechanic didn't put in a PCV. That's the only other thing I would think of that may be relevant.
    Jeff
  11. #91 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    Circled is the only pcv passage that is used in my setup. I have a front valve cover breather. Yeah at this point im really at a loss as well.
  12. #92 Re: Issue after intercooler install, car revs high then drops way low
    GXP Level Member
    Mar 2015
    Tomball
    That looks like a threaded bolt hole, what is the hole next to the red circle?
  13. #93 Re: Issue after intercooler install, car revs high then drops way low
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by J57ltr View Post
    That threaded hoke is for a fuel rail stud, the pcv is the bigger hole next to it.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  14. #94 Re: Issue after intercooler install, car revs high then drops way low
    GXP Level Member
    Mar 2015
    Tomball
    Ok, that's what I was thinking. Is there and coolant there?
  15. #95 Re: Issue after intercooler install, car revs high then drops way low
    Montgomery, IL
    OP. These are the pcv holes..make sure your rear is not blocked by rtv, and make sure you put rtv around the front one even though it's blocked off by the ic, you can still get a Vac leak from it. Doesn't fix your coolant issue but possible vac leak, pcv issue...and you should ditch the breather cap imo and do it correctly so it can be tuned better. If you feel heavy sucking on the oil cap while engine running you have a pcv issue that can cause problems with gaskets as stated...hope you get it figured out.
  16. #96 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    The smaller hole is one i drilled out to get the rear pvc working with the zzp stage 2 IC. usually they make the hole bigger but i just have it at that size. Here is a pic of what zzp's modified lim's look like.
    Both the holes were surrounded with rtv when the ic was installed, its just hard to see in this pic.
  17. #97 Re: Issue after intercooler install, car revs high then drops way low
    Montgomery, IL
    Quote Originally Posted by Beatdowncity View Post
    Ahh got it...might need to open it up a little bit more..
  18. #98 Re: Issue after intercooler install, car revs high then drops way low
    GXP Level Member
    Mar 2015
    Tomball
    I would think with a filter there it would make a pretty heavy sucking noise. It's an easy check. If there was an PCV issue it wouldn't be able to cause a leak in coolant I wouldn't think. I'm sure it's not good, and agree the PCV should work as intended. So with the revised manifolds there is a second passage from the manifold? I'm guessing they were picking up volume? Does anyone know the reason for the difference? I don't know enough about it to say wether modifying it would make the situation worse but we gotta find the root cause I would think with tv feather in there even if there was an PCV issue it wouldn't be able to cause a leak in coolant. I'm sure it's not good, and agree the PCV should work as intended.rather than just start modifying things. I can't think of another thing that could cause it. I looked at the pics carefully and the 2 part IC adapter has A small manifold area inside it. Depending on a lot of things this can actually create a restriction. It's the same effect used in the stock air box. That is a Helmotz resonator. I may be overthinking this.
    Jeff
  1. How to install your WBS Intercooler
    By machinegunsquid in forum How To Write-Ups/Tech Tips
    Last Post: 07-11-2019, 08:02 PM
  2. 1999 Grand Prix GT Trans revs high
    By pilgrim in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 12:42 AM
  3. high revs as i start car
    By Jrs1987 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2011, 06:28 PM
  4. High Revs, Late Shifting, and low HP
    By Wigsos in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-30-2010, 09:24 AM
  5. how do you install an intercooler??
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 05-25-2008, 12:15 AM
