Thread: Cleaning drive by wire TB on 05'
Results 1 to 6 of 6
  1. #1 Cleaning drive by wire TB on 05'
    GXP Level Member
    Mar 2015
    Tomball
    I'm Pulling the throttlebody to clean it to see if this is what is causing the car to stumble and die. Is there anything I need to know before I start like having it set in a certain position or anything?
    Thanks,
    Jeff
  2. #2 Re: Cleaning drive by wire TB on 05'
    SWPA
    Nope, pull it clean it, reinstall.
  3. #3 Re: Cleaning drive by wire TB on 05'
    GXP Level Member
    Mar 2015
    Tomball
    So I went ahead and cleaned my TB on my 05'GTP, here are a few pics.
    It's really easy to remove and has a reusable oring gasket. There is a water passage so note that.
    Nasty TB
    Fully open
    Fully closed
    Natural position
  4. #4 Re: Cleaning drive by wire TB on 05'
    just so your on the right page here. its inside the tb tube that needs to be cleaned of all the carbon, the sides and back of the butterfly flap too.
  5. #5 Re: Cleaning drive by wire TB on 05'
    GXP Level Member
    Mar 2015
    Tomball
    Of course, I was thinking more of what the gearbox should look like. The inside was very clean. I figured everyone knew what a dirty TB looked like. Sometimes I start typing and get distracted and leave out most everything I was going to say.
    Jeff
  6. #6 Re: Cleaning drive by wire TB on 05'
    ok, just making sure you weren't going down the wrong path here. carry on and tinker as you will.....
  1. 04+ ZZP Gauge Pod New Condition, 04+ Drive-by-Wire Throttlebody
    By ADrugDealer in forum For Sale - Parts
    Last Post: 05-16-2014, 11:33 AM
  2. GXP clunk from park to drive, drive to reverse..
    By sasquatch094 in forum General Tech Discussion
    Last Post: 02-13-2014, 04:27 PM
  3. Looking for some speaker wire and a new ground wire.
    By Bluemagic in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:41 PM
  4. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  5. drive by wire
    By echarleswhyte in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-07-2010, 09:11 PM
