Thread: Sorry to be lazy but a performance question
Results 1 to 13 of 13
  1. #1 Sorry to be lazy but a performance question
    Mar 2015
    United States
    I recently got back to the Grand Prix part of the family 2 weeks ago after damaging my Grand Am. Wish I had never left by the way.
    Now I have the 3800 series II Supercharged. It has a K&N filter on it but lately as I look under the hoods online I see the Cold air intake or perhaps more direct flow intake. Is this worth my time to look into? I would be fine with more HP and/or increased MPG even if it only by a small amount.
  2. #2 Re: Sorry to be lazy but a performance question
    St. Louis
    Dump the K&N, clean the MAF that is likely covered in oil now, and make your own HAI as you see in the pics. More noise from blower, same HP.
  3. #3 Re: Sorry to be lazy but a performance question
    Quote Originally Posted by FordMan77 View Post
  4. #4 Re: Sorry to be lazy but a performance question
    Mar 2015
    United States
    Thanks I happen to know just enough to get myself into trouble, in the sense Im not a mechanic/gear head. High Air Intake? Basically going off the reference that the tubing is 3" diameter and getting a filter for that size and securing it accordingly? That way I can use much of the existing hardware as possible.
  5. #5 Re: Sorry to be lazy but a performance question
    Hot air intake.
    Go do some reading.
    Then come back.
    General Tech section, Safely modding your 3800. Or google. It's been covered a trillion times here. Along with making your own intake threads and How-To's.
  6. #6 Re: Sorry to be lazy but a performance question
    Mar 2015
    United States
    Followed the above mentioned check and I am systematically going down the top 10 for safely modding the 3800. However I am now finding that after adding the cone filter my GTP occasionally stalls out at a red light stop. I have cleaned the MAF, oil/ Filter Swapped, what am I missing here? I would have thought that the computer would have compensated for HAI/CAI flow that the car now has.
  7. #7 Re: Sorry to be lazy but a performance question
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Swapping "Cone Intakes" isn't going to cause your car to stall out. There's another issue.
    When swapped intakes, did you leave something unplugged? MAF, or some sensor on the Throttle Body? or maybe you have a vacuum leak?
  8. #8 Re: Sorry to be lazy but a performance question
    Mar 2015
    United States
    I will double check the MAF and other sensors. It was suggested by another car guy that since this causes the car to run lean it might be too lean. I guess that goes back to your statement about the other sensors though. That if the computer is getting all of its information it should not stall out.
    Can I clean the IAC and IAT sensors with the MAF cleaner? Perhaps those are the culprits. They seem to be the only other ones in that neck of the woods that might affect this.
  9. #9 Re: Sorry to be lazy but a performance question
    Nov 2013
    Wisconsin!
    No way it's running lean and stalling from an air filter......
  10. #10 Re: Sorry to be lazy but a performance question
    Jun 2011
    Quote Originally Posted by koRnhead View Post
    Quote Originally Posted by blueguy View Post
    Post pictures before touching anything. Bet we can tell you...that you probably damaged the MAF when you removed it to clean it.
    What these guys said. There is absolutely no way you're car is running lean due to adding a cone intake. All the intake is going to change, is the sound of your blower. Other than that, nothing at all.
    Take a picture and post it here, like Nick stated. Either your MAF is unplugged or it's been damaged. I'm 99% sure on this.
  11. #11 Re: Sorry to be lazy but a performance question
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Sounds like you left your maf unplugged. Takes 2 seconds to look
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  12. #12 Re: Sorry to be lazy but a performance question
  13. #13 Re: Sorry to be lazy but a performance question
    Mar 2015
    USA
    Sounds like something is unplugged for sure. Do you have a check engine light on?
    How does the car idle?
  1. Lazy shifting
    By savage93 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2013, 10:25 PM
  2. To Lazy
    By Hidenface in forum Introductions/Noob Questions
    Last Post: 11-02-2012, 07:04 PM
  3. performance question
    By braz667788 in forum Introductions/Noob Questions
    Last Post: 09-11-2012, 12:27 AM
  4. Rap Real Lazy
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 06-01-2011, 03:19 PM
  5. Greetings from The Lazy R !!!
    By thelazyr in forum Introductions/Noob Questions
    Last Post: 08-27-2010, 06:21 PM
