I will be going with an XP/130# crows and manley modded retainers build.
For the Viton valve seals zzp states it has .020" of extra clearance. Intense gives you an option of stock .510" or machined .500".
Is zzp the same as intense's machined? The numbers aren't adding up.
Intense does state if the guides have or have not been milled down for a s1x build then the .500" are needed.
