Wires and plugs were changed by the owner.
Aren't you the owner? I see it was the previous owner from other posts. Just goofing around
I also think the boost gage quit working when the check engine light came on.
The gauge and light are not connected. Check that the MAP sensor is connected to both it's plug and vacuum line. It is possible that the misfire/knock is bad enough that the pcm is not allowing boost.
My buddy says that #3 cylinder has 100% leakdown.
Meaning .. it will not hold compression? If so, you have a problem in #3 that might look like the below pics. Might have a chipped piston.
No compression
And.. missing piston
