Thread: help needed
Results 1 to 4 of 4
  1. #1 help needed
    GT Level Member sdenton8's Avatar
    marshalltown, iowa
    I have a 04 grand prix gtp and I have problems with it. It starts half the time and other times it dont. If it does start it runs for a second or two then dies. I can hear the fuel pump prime sometimes. But not every time I turn the key to on. Its a 04 so I dont believe it has a resistor. I checked the fuses and relay. Both seem to be good. I also check the shradder at the rail and fuel comes out. Today it died on me and would start then die. I pulled key and it kept dinging like the key is in the ignition when it wasnt.
  2. #2 Re: help needed
    Jul 2014
    New Jersey
    I can't help but i would love to hear the answer i have a similar thing atm
  3. #3 Re: help needed
    a maf on the fritz has been know to act like this. try unplugging the maf car off, then start it up. if it runs better its the maf. bill always says to try tapping the maf too while the cars at idle. some times the engine will clear up with one tap, then act up with another tap.
  4. #4 Re: help needed
    marshalltown, iowa
    Ill try that tomorrow. Im going to clean the maf and throttle body.
  1. a little help needed
    By BBluelandyacht in forum General Grand Prix Discussion
    Last Post: 02-23-2012, 09:12 PM
  2. 400+hp Needed
    By crzystve42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2012, 07:49 PM
  3. help needed!
    By tcafego in forum Audio, Security & Visual Electronics
    Last Post: 09-12-2011, 04:02 PM
  4. CD player instal, parts needed, advice needed
    By timmaayy2323 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2011, 08:53 PM
