Thread: 1999 GP GTP motor/transmission problem
Results 1 to 4 of 4
  1. #1 1999 GP GTP motor/transmission problem
    Mar 2015
    hampden, ma
    Ok so last night I was driving my car down the road and I was cruising at like 40ish I go to accelerate and my car acts like it's in neutral, engines revving up but it won't go into gear. So I pulled into a nearby parking lot and turned off the car, when I went to start it it wouldn't crack... One of my friends was with me and they thought they could hear the starter working (or at least trying to) but the belts weren't moving... What could be the problem and how much is it gonna run me to fix it?
  2. #2 Re: 1999 GP GTP motor/transmission problem
    maybe try putting the car in neutral then try to start it. or also jiggle the shiftier back and fourth.
    you can also try jumping the starter motor. as well as testing for power at the small wire on the starter when the key is turned to crank.
  3. #3 Re: 1999 GP GTP motor/transmission problem
    Mar 2015
    hampden, ma
    I Did tr. Putting it in neutral to start it and the same thing happened and I will give the other things a go when I have the chance probably tomorrow
  4. #4 Re: 1999 GP GTP motor/transmission problem
    Hampden isn't that far from me. LMK if you'd like a hand.
  1. Identify this Transmission??? Can it be made to work in my 1999 GTP?
    By Shmoke in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-14-2013, 10:39 PM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. 1999 Grand Prix Transmission leak
    By sdilliha in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2010, 11:56 AM
  4. 1999 Grand Prix Transmission headaches...please help!
    By istorm70 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2010, 03:40 PM
