Thread: TB elbow with bung
Results 1 to 6 of 6
  1. #1 TB elbow with bung
    Pittsburgh
    Looking to replace the accordian coupler on the WizAir for a smooth silicone one but I cant find one with the pvc bung like this one. Any ideas on where to get one?
    TB elbow with bung Attached Images
  2. #2 Re: TB elbow with bung
    Oct 2011
    Toledo, OH
    I used a stainless steel one and just drilled a hole in the rubber coupler for the PCV
    7"
  3. #3 Re: TB elbow with bung
    Kemmerer, Wyoming
    I have a couple tubes that might work for you, I will get some pictures and post them later, if you want. one of the tubes is polished aluminium, and would need to be cut because its too long, and then you would need to drill a hole for the IAC sensor. I also have a black plastic tube that is probably about what you would need, and has the hole already for the sensor.
  4. #4 Re: TB elbow with bung
    hangover park IL
    on my 04 its the OEM pcv elbow with the tube with a grommet...others ive just cutoff the elbow at 2" and shoved into the silicone elbow, hole cut undersized and using a new sharp exacto knife...no need to seal it with silicone.
    the other end was hacked off and shoved into an old OEM ignition cable coil boot (yank it off yer old set/spares)...the oem elbow falls apart, the spark plug wire boots tend to be a silicone elbow. lasts alot longer and doesnt split like the oem elbow at the blower nipple
    connecting the two ends
    ~James~ Psychotic Gearhead
  5. #5 Re: TB elbow with bung
    Pittsburgh
    Thanks. Let me know.
  6. #6 Re: TB elbow with bung
    SWPA
    All I did was drill my intake and install a grommet. Its hard to see in the photo because of where I placed it but its there.
  1. HELP. WHAT SPECIFIC SPARK PLUG NON FOULER WILL THREAD IN o2 BUNG
    By MrDniceL36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2014, 02:21 PM
  2. Wideband Bung Location
    By Silver GTP in forum General Tech Discussion
    Last Post: 08-02-2010, 09:19 PM
  3. O2 Bung plug
    By Sabrewings in forum General Tech Discussion
    Last Post: 05-30-2008, 12:31 PM
