I have a couple tubes that might work for you, I will get some pictures and post them later, if you want. one of the tubes is polished aluminium, and would need to be cut because its too long, and then you would need to drill a hole for the IAC sensor. I also have a black plastic tube that is probably about what you would need, and has the hole already for the sensor.
