Thread: Mother******* Crank bolt
Results 1 to 18 of 18
  1. #1 Mother******* Crank bolt
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    The title says it all. It's as stuck as stuck can be. I've looked around and found plenty of other threads on here and other sites that suggest a host of ideas. So far, i've only tried an Impact wrench (not a cheap one either, kobalt) @ 125 psi. Did not make a dent. I've also put a ton of WD-40 on it and tried it again. Nothing.
    So my question is which method is preferred? The engine is still in the car, btw.
    Should I hit it with a little heat and try it with the impact after that? My only way of doing this btw is getting a cheap handheld propane torch. I'm not big on this idea, as it's right next to the oil filter and makes me a little uncomfortable. But if it's the best way i will try it.
    Should i try the starter method? This again, is a little janky and would not be my preferred way. But i'm willing if you guys have had success with it.
    Should i try to jam the flywheel? I'm leaning toward this. Anybody had any success with this?
    And any other methods that you guys can think of that might work. I got a ton of tools and an air compressor so that's not an issue. Just need ideas as i'm giving it another go tomorrow.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  2. #2 Re: Mother******* Crank bolt
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    Long breaker bar, block the flexplate and put the kibosh on it, it's a bear to get off
    Team JB-Weld
  3. #3 Re: Mother******* Crank bolt
    Oct 2014
    portland oregon
    Quote Originally Posted by dezebe1 View Post
    this is how i did mine was out of car tho
  4. #4 Re: Mother******* Crank bolt
    When stuck, I did the starter trick. It worked like a champ.
    There's really a limited amount of space for a socket and big mother breaker bar.
    I'd also look over your compressors regulator. If it'll go 150, you'll likely get it.
  5. #5 Re: Mother******* Crank bolt
    Jan 2013
    Raleigh, NC
    It'll go up that high. I'll try that. If after a couple of tries nothing, then i guess i'm doing the flywheel method.
  6. #6 Re: Mother******* Crank bolt
    Buffalo
    Starter. Fast. Easy. Simple.
  7. #7 Re: Mother******* Crank bolt
  8. #8 Re: Mother******* Crank bolt
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I use a good 1/2" breaker bar with a long cheater pipe and block the flexplate, also a 6 pt impact socket. If you have a 3/4" breaker bar/socket, even better.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  9. #9 Re: Mother******* Crank bolt
    Mercer, Pa
    Starter!!
    I had to do one with the engine out once. My problem was I was flipping the engine around on the floor. Starter with your strongest breaker bar.
  10. #10 Re: Mother******* Crank bolt
    Nov 2011
    NY
    Quote Originally Posted by sseilmnop View Post
    Starter!!
    Hahaha the visual making me cry! Lmao!!!
  11. #11 Re: Mother******* Crank bolt
    Bastard Reptile's Avatar
    Kansas City, MO
    Starter trick works.
    Heat also works.
  12. #12 Re: Mother******* Crank bolt
    Nov 2013
    Wisconsin!
    I take out the big 3/4 impact. At 150psi that thing will turn the earth.....
    If you can get your hands on one it will do the trick.
  13. #13 Re: Mother******* Crank bolt
    Mar 2015
    Aurora, CO
    I usually just put a big ole ratchet on it and and rest the handle of the ratchet somewhere on the subframe where it wont move around too much. Disable either fuel or spark. Then make sure nobody is standing in the wheel well. and crank it. The starter is plenty powerful enough to break it loose.
    Do not jam the flywheel! This method works great! I have even dont it with the subframe out of the car just by jumping terminals on the starter when its got a good strong battery source.
    I can almost guarantee no impact bought from a store will ever remove a crank bolt(if torqued properly) I wanna say it was like 110 ft lbs plus 90 deg. Which ends up coming to a little over 220 ft/lbs. I think about the only impact that would do it would be a Snap on, or Cornwell or similar. Turning up the air pressure really doesnt do much. Not to mention if its not the great impact pressure that high could damage it before it would get anything loose.
    98 GTP-N*T.B., Gen V Swap, S2 I.C., Elec. Water Pump, 8 Rib Conv., 3.25" Pulley, Race Rad, Headers, 3" catback, And Basically everything ZZP makes for Susp and Steering, GXP brakes, 245/45 FR 265/40 RE, 2012 Corvette Z06 Steering wheel, and tons more but w/e. Tuning done by MAC auto
  14. #14 Re: Mother******* Crank bolt
    Jul 2012
    Clayton,NC
    Harbor freight earthquake 100psi hit for 5 secs. done
  15. #15 Re: Mother******* Crank bolt
    Mar 2015
    Aurora, CO
    Quote Originally Posted by gtpguy98 View Post
    harbor freight blows! I bought that (earthquake) pos. 1/2 in. More like aftershock. Says on the box rated at 740 ftlbs. My ass. Bought this piece of junk specifically for getting my crank bolt off. Couldn't even get my wheels off with it. Took it back immediately tried the 3/4 inch earthquake. 900ftlbs. Still nothing. Rule of thumb with tools. Especially power tools. U get what u pay for. People ask me all the time... Mostly my mom or my g/f, what's the difference they all have lifetime warranty. My answer jus always the same. The difference is even with craftsman, u get a lifetime warranty and if u r doing a good amount of wrenching u will b back at sears all the time replacing tools. Buy snap on and u will never have to use the warranty. I ended up finding a guy on Craigs selling all his air tools. Got 2 impacts, an air ratchet, grinder, hammer and a bunch of sockets and chisels and crap for just under 500 bucks.
  16. #16 Re: Mother******* Crank bolt
    SWPA
    Haven't had to do it for the GP yet, but starter trick is the way to go. Did it many times on other cars without ever failing.
  17. #17 Re: Mother******* Crank bolt
    Jan 2013
    Raleigh, NC
    OK. Update: I tried turning up the air pressure on my compressor to the max. Still did not touch it.
    So I used the starter trick. I don't have a breaker bar and neither does my local Lowes so I just put some pvc over my 1/2 ratchet and went for it.
    Worked like a charm. I took a video. I'll post it in a minute.
    In the meantime, does anyone have any suggestions of where to place the jack on the subframe when I go to lower it tomorrow? Or any other cam install helpful suggestions?
  18. #18 Re: Mother******* Crank bolt
    Jan 2013
    Raleigh, NC
  1. How many times can a crank bolt be re used?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2012, 06:26 AM
  2. 24 mm bolt on crank?
    By legend in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2012, 05:01 AM
  3. Crank Bolt Will Not Come off
    By BoilerTom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2012, 08:03 AM
  4. problems removing crank bolt from hub
    By BonesSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2010, 07:50 PM
  5. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
