Thread: 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
Results 1 to 10 of 10
  1. #1 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
    Dec 2014
    Akron,Ohio
    Hi,
    I'm new here and have a very clean 02 GTP that I love but can't figure out my misfire. It's been to my buddy's garage who's a Master Tech and he's done everything. Code is P0303 Cylinder 3 misfire. It runs down the highway smoothly but at idle it really rocks at times and doesn't seem to have the gitty up it should. Wires and plugs were changed by the owner. The check engine light wasn't on when I bought it. I also think the boost gage quit working when the check engine light came on. I replaced the coils. It looks like it has a new intake gasket and head gasket. My buddy says that #3 cylinder has 100% leakdown. I'm dying to get this check engine light off and get this thing running like it should. Also, checked the valve springs, they were fine and he soaked the valves w/Seafoam thinking that carbon build up may be possible... still having a problem. I thought 3800's were almost bullet proof. Any ideas? It has 91K miles. Any help or ideas will be appreciated. Thanks.
    Mark
  2. #2 Re: 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
    What brand plugs and gap?
    They don't like platinum plugs and if the gap is at .060 or bigger reduce it to .050.
  3. #3 Re: 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Check all your vacuum lines and the BBV for leaks. Also if you have a way to scan check your injector pulse width and make sure the injector is doing it's job.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  4. #4 Re: 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
    Dec 2014
    Akron,Ohio
    Don't recall what brand the plugs are but I'll check that and the gap. What plugs are recommended? Thank you.
  5. #5 Re: 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
    Dec 2014
    Akron,Ohio
    Sorry but what is the BBV? I know it's been checked for vac leaks. I'm not sure if the injector pulse width has been checked. I'll ask. Thank you.
  6. #6 Re: 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
    St. Louis
    Dumb question, but you are running at least 91+ octane in it, right? Must use premium fuel in it.
    BBV= Boost Bypass Valve.
    On the plugs, see below:
    Spark Plugs - Change out those stock spark plugs with new ones to restore any lost power. Brands that most tend to go with are either Copper Core Autolites or NGK Spark Plugs. Get these at your local auto parts store also. They range as follows in order from hottest to coldest plugs...remember...you want the hottest spark possible...so running a super cold plug on a larger pulley to combat knock isn't the best plan...ACD's, AL606's, and AL605's are basically for stock cars or very small bolt ons still running the stock S/C Pulley or modded N/A guys...you want to keep a hot spark. NGKTR55/AL104's for your 3.4" Setup, TR6's are a tad cooler...best used around the 3.25" pulley area, and AL103's...are for the extreme supercharged application...3.0" pulley or lower. Here is a picture to reference the firing order and the correct coil number if yours aren't numbered or you just need a quick reference picture: http://i33.photobucket.com/albums/d6.../plugwires.jpg
  7. #7 Re: 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
    Dec 2014
    Akron,Ohio
    Quote Originally Posted by FordMan77 View Post
    BBV. Thank you. Yes, I run 93 in the car. I'm going to try and check the plugs tonight. Thanks again.
    Mark
  8. #8 Re: 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
    Aren't you the owner? I see it was the previous owner from other posts. Just goofing around
    The gauge and light are not connected. Check that the MAP sensor is connected to both it's plug and vacuum line. It is possible that the misfire/knock is bad enough that the pcm is not allowing boost.
    Meaning .. it will not hold compression? If so, you have a problem in #3 that might look like the below pics. Might have a chipped piston.
    No compression
    And.. missing piston
  9. #9 Re: 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
    Dec 2014
    Akron,Ohio
    No compression
    I'll check the vac and connector to the MAP. I have about 70 compression on cylinder 3 and 120 on the other 5 cylinders. 70 is on the line of acceptable. The leakdown on cylinder 3 is 100 meaning that I've got a valve or something that's causing the problem. Could a valve seal or heavy carbon on a valve in cylinder 3 be causing the problem? Next I think is a carbon clean to see if carbon build up is the problem. I just want to eliminate everything possible before removing the head.
  10. #10 Re: 02 GTP w/Misfire, No Boost on Gage and Rocks at Idle
    you can try seafoaming it. that would clear up any carbon on the valves or seats.
  1. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  2. Misfire under Boost please help!
    By Blaine Beast in forum Introductions/Noob Questions
    Last Post: 02-20-2013, 07:51 AM
  3. 04+ Boost Gage?????
    By lambokit in forum 04+ Specifics
    Last Post: 06-14-2011, 08:44 AM
  4. Computer boost gage
    By cmal37 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 11:36 PM
  5. Misfire when getting boost on 99 gtp help!!
    By Machzzzz1 in forum General Tech Discussion
    Last Post: 11-21-2010, 10:20 PM
