Thread: Front end noise..
Results 1 to 6 of 6
  1. #1 Front end noise..
    Feb 2015
    saginaw
    Ok this is kind of a stupid question. But im trying to narrow this problem down before I go replacing a bunch of things.. When I hit bumps and go down crappy roads my front end sounds really loose..the noise is really annoying and sounds like the tires are loose ha its hard to explain but you can feel it in the pedals and the steering wheel. Im thinking struts maybe?? Or tie rods?? Just need somewhere to start!
  2. #2 Re: Front end noise..
    Enfield, CT
    worn struts mounts, worn control arm bushings, bad hub, broken end links, etc. Jack up the car and start inspecting.
  3. #3 Re: Front end noise..
    Sep 2014
    Worcester, MA
    Check your sway bar end links.
  4. #4 Re: Front end noise..
    Dec 2014
    Check ball joint. Wife's car was same way. Found a bad ball joint. Was very loose.
  5. #5 Re: Front end noise..
    Feb 2015
    saginaw
    Ok thanks guys.. another thing is im getting vibration in the steering wheel and u can feel it in the seats and front end. I replaced both front hubs but did nothing
  6. #6 Re: Front end noise..
    Dec 2014
    Glad to help. Tire may be out of balance or out of round.
  1. New front brakes and now a squeaking noise up front
    By Trann14 in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2013, 08:45 PM
  2. Front end noise
    By jmn in forum Introductions/Noob Questions
    Last Post: 04-21-2013, 05:07 PM
  3. Front end noise
    By Foot9561 in forum Brakes/Suspension/Chassis
    Last Post: 01-31-2013, 09:49 PM
  4. Front End Noise
    By dlsr in forum General Grand Prix Discussion
    Last Post: 07-11-2012, 12:52 AM
  5. Front end noise
    By GTP2188 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2011, 01:06 PM
