Thread: GTP Swap
Results 1 to 2 of 2
  1. #1 GTP Swap
    Mar 2015
    Miami
    I wish to swap motors with an 07 GTP I found in a junkyard. Are the Motor mounts on an 07 GTP the same as a 97 GTP, and are they located in the same spots?
  2. #2 Re: GTP Swap
    07 will have an aluminum oil pan and a different mount. They are in the same place. However they are different. I like the 07 design better. You will also need a TB adapter if you are buying a complete engine.
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
