Thread: Is the throttle body filter necessary?
Results 1 to 20 of 21
  1. #1 Is the throttle body filter necessary?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    I searched for this, but the search function isn't too awesome around these parts.
    Anyways, I'm cleaning my TB tomorrow and was looking at it tonight with regard to getting off the filter. I know the NA 3.8s don't even have them so are they actually necessary on the Supercharged engines? I read conflicting stories about removing the thing.
    Thanks guys.
  2. #2 Re: Is the throttle body filter necessary?
    GTP Level Member buickman104's Avatar
    NYC
    The honeycomb straightens the air flow over the MAF sensor for better resolution. Remove it and the car will feel faster because you will be running a little lean. Then you will knock and the pcm will adjust timing and little extra power will be lost. Just leave it there and let it do its job.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: Is the throttle body filter necessary?
    Mar 2014
    Tucson
    Search for "laminar flow" There's some interesting reading material on the subject. I learned a lot form the few threads I read.
    http://www.grandprixforums.net/threa...t=laminar+flow
  4. #4 Re: Is the throttle body filter necessary?
    Sep 2014
    St. Paul, MN
    Thanks guys.
    So I assume it's fairly easy to remove the filter once the little ring is removed?
    Also, I just wanted to ask if in your all's opinion my filter is damaged or if they all look a little smushed in certain spots?
    https://onedrive.live.com/redir?resi...nt=photo%2cjpg
    Thanks for the replies.
  5. #5 Re: Is the throttle body filter necessary?
    looks fine to me. maybe you can make look a bit straighter when its removed. or flip that spot to the top.
  6. #6 Re: Is the throttle body filter necessary?
    Jul 2012
    Chicago
    Looks undamaged, leave it in there!
    -Carl
  7. #7 Re: Is the throttle body filter necessary?
    Leave it.
    Don't be a ricer.
    It's not a filter.
    It's in place so the MAF gets a smoother reading from airflow.
  8. #8 Re: Is the throttle body filter necessary?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    N/a 3.8 dont have the honeycomb? My n/a does..
  9. #9 Re: Is the throttle body filter necessary?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Grimsin View Post
    I figure they should. My Firebird's 3800 did at least.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  10. #10 Re: Is the throttle body filter necessary?
    Apr 2011
    Elk Rapids, Michigan
    My 2000 GT had one. It is needed! Your idle would be erratic without it. It is a flow straightener fir the MAF sensor.
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  11. #11 Re: Is the throttle body filter necessary?
    Enfield, CT
    Every 3800 I encountered had one...
  12. #12 Re: Is the throttle body filter necessary?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    I don't have one on my car.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  13. #13 Re: Is the throttle body filter necessary?
    GT Level Member K Slice's Avatar
    Jul 2013
    Traverse City MI
    Take it out and replace it with one of these!
    *Sarcasm
    Is the throttle body filter necessary? Attached Images
  14. #14 Re: Is the throttle body filter necessary?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    At least OP asked here and not on a Facebook group. 85% of those guys all say ditch it because they seen no ill effects.
    2012 F150 STX
    - Gonna be a race truck
  15. #15 Re: Is the throttle body filter necessary?
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Mine has one
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  16. #16 Re: Is the throttle body filter necessary?
    St Thomas Ontario
    I did have mine out for over a year, overkill even did a tune with it out the screen in for me(which he knew about) and had no issues dialling in a tune, but I did have a very smooth intake on it and got rid of the accordion tubing.
    but then i just threw it back in one day for peace of mind
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  17. #17 Re: Is the throttle body filter necessary?
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I've seen no difference with or without it. Wouldn't go through the trouble of removing since it does nothing for me. Ymmv obviously.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  18. #18 Re: Is the throttle body filter necessary?
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    You can remove it and have your pcm tuned to compensate. I have a ZZP stage 2 throttle body and had Will retune my original Overkill pcm to compensate for the larger tb. When you go with a larger tb, you lose the screen and whatever benefits it provides. Remember performance gains are cumulative and the tb is just part of the puzzle. I monitor my engine using three aeroforce gauges in a pillar pod, have no performance issues and have that quiet smooth sleeper idle.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  19. #19 Re: Is the throttle body filter necessary?
    May 2008
    Schuyler, NE
    It's the maf that needs the screen, not the tb. If you upgrade to an lq4 maf, it should still have the screen.
  20. #20 Re: Is the throttle body filter necessary?
    Jan 2009
    ny
    My mistake, the Maf on my 05 Impala SS goes into the throttle which is after the screen. I didn't realize the Grandprix's Maf is separate from the tb.
    factory tb with screen
    Factory tb without screen
    ZZP pic taken from their site, their tb is too big for the factory screen to fit.
  1. Detaching and Reattaching Throttle Cables to L67 Throttle Body
    By komrad36 in forum How To Write-Ups/Tech Tips
    Last Post: 05-01-2017, 12:09 PM
  2. cone filter on throttle body
    By GTP Ryan in forum General Tech Discussion
    Last Post: 03-19-2011, 08:44 PM
  3. Cone filter on Throttle body??
    By flash527 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 09:14 PM
