Thread: top swapped and now a problem
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    i tested my injectors and three of them are not working and yeah it did that, I'll replacing all injectors and going from there
  2. #22 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    Only air came out btw, no fuel
  3. #23 Re: top swapped and now a problem
    if its popping out the intake thats almost always a ignition issue. like plug wires being on wrong.
  4. #24 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    Okay thanks, my brothers a toyota mechanic I'm gonna have him find the spark issue
  5. #25 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    Okay so my brother hasnt been free yet, so i tested spark, checked the lines... Again. Both are in working order, i noticed a leaky fuel pressure relief valve, not the regulator.
  6. #26 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    Found the problem, due to a slight variation between harmonic balancers my new one rubbed on the crank sensor causing the timing to be incorrect, after some adjustments everything ran fine
  1. 98 GP GT L67 swapped needs pcm which one??
    By 98PONTIAC in forum General Tech Discussion
    Last Post: 12-27-2012, 03:14 PM
  2. Top swapped
    By Dragon1972 in forum PCM Tuning
    Last Post: 05-03-2012, 09:07 AM
  3. Top swapped L26 goes BOOM :D
    By nitroheadz28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-20-2012, 08:05 PM
  4. Swapped 05 L32 into an 04 L26 HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 04-20-2011, 07:32 PM
  5. L67 Swapped
    By 99LuminaLSC in forum Chevrolet Lumina
    Last Post: 12-15-2007, 08:57 AM
