Thread: Where to start, upgrading GTP
Results 1 to 20 of 31
  1. #1 Where to start, upgrading GTP
    Feb 2015
    Louisville, KY
    A few months ago I purchased my 2002 Grand Prix GTP. 153k miles. Black/2dr/fully loaded. I love it, exactly what I was looking for! It had an exhaust leak when I bought it but I got it fixed right away. Replaced the one fog light that was out, now I iust am missing a side skirt I'm just waiting on it to warm up before I fix that. I'm just wondering when I get to start doing upgrades to my car what exactly should I be starting with? Exhaust? Pulley? Cold air intake? I'm not an expert but I do love cars, love learning new things about my car and that's why I'm here. Anybody got any ideas on where I need to start?
  2. #2 Re: Where to start, upgrading GTP
    Enfield, CT
    Yes. this question has been asked many many times. the SEARCH bar at the top to the left of the 2 cars will have all the info you need
  3. #3 Re: Where to start, upgrading GTP
    Feb 2015
    Louisville, KY
    Well appreciated, sorry for wasting a thread
  4. #4 Re: Where to start, upgrading GTP
    Enfield, CT
  5. #5 Re: Where to start, upgrading GTP
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Lower intake gaskets is a good start.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  6. #6 Re: Where to start, upgrading GTP
    Enfield, CT
    Basic info about them is that they are a GM W-Body, Coupe/Sedan, FWD, 4-spd automatic transmission (Code-Named the 4T65E-HD; 2.93 gearing) 3800 Supercharged V6 platform (Code-named L67 for 97-03 or L32 '04+), rated at 240 hp (260 horse for the '04+ cars)and 280 ft. lbs. of torque from the factory. Figure your 20%-ish drive train loss and you’ve got your basic wheel horsepower numbers. The N/A Grand Prix was also powered by the 3800 V6 (Code-Named L36 for 97-03 or L26 '04+) and mated to a 4-spd automatic transmission (Code-Named 4T65E; 3.29 gearing, Keep in mind in '04 The GTP Comp G used 3.29 gearing from the factory for a way better setup) making 200 hp and 225 (add 5 ft. lbs. for the '04+ cars) ft. lbs. of torque. If you have just bought your ’97-’08 WBody and are looking to modify it then please take these steps to insure safer modding steps. Begin with your typical maintenance first, such as:
    1) New Spark Plugs (You can upgrade spark plugs at this time if you wish)
    2) New Spark Plug Wires (You can upgrade spark plug wires at this time if you wish)
    3) Oil/Oil Filter Change
    4) Fuel Filter Change
    5) Coolant System Flush (Replace Dexcool with Yellow/Green Coolant)
    6) New Thermostat (You can upgrade to a 180*/160* Thermostat at this time if you wish)
    7) Lower Intake Manifold Gaskets/Coolant Elbows (2)
    8) Transmission Pan Drop/New GM Transmission Filter (Replace 3-4 quarts with Dexron VI, not Dexron IV)
    9) New Brake Pads and/or Rotors
    10) Supercharger Oil Change (Replace with 2 New Bottles of GM Supercharger Oil)
  7. #7 Re: Where to start, upgrading GTP
    Cibolo, TX
    My favorite is #5 on the list.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  8. #8 Re: Where to start, upgrading GTP
    Enfield, CT
    Quote Originally Posted by 99GT2dr View Post
    lol
  9. #9 Re: Where to start, upgrading GTP
    Cibolo, TX
    Quote Originally Posted by HighOctaneRacing View Post
    lol
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  10. #10 Re: Where to start, upgrading GTP
    Feb 2015
    Louisville, KY
    Actually I was going to get my transmission flushed recently and someone told me not to because I don't know when the last time it has been done and they have heard that sometimes putting brand new fluid in the transmission that hasn't been changed in a very long time can start causing problems. Hopefully that made sense.. Anybody know anything about this?
  11. #11 Re: Where to start, upgrading GTP
    Feb 2015
    Louisville, KY
    I really appreciate all of this very much. This is EXACTLY what I wanted to here and I love learning these things about my GTP. Can't wait to get a jump on it starting with that list of maintance work. I will focus on all 10 of these steps before moving on to any additional upgrades.
  12. #12 Re: Where to start, upgrading GTP
    you heard right. see how your fluid looks now, is it nice and red? if so then just drop the pan, change the filter, add 8 quarts of new fluid.
    reuse the factory gasket. when you have both in hand you'll see why. clean it and the pan with brake cleaner and re use it.
  13. #13 Re: Where to start, upgrading GTP
    Feb 2015
    Louisville, KY
    Well appreciated, I will get to this as soon as I can!
  14. #14 Re: Where to start, upgrading GTP
    Bastard Reptile's Avatar
    Kansas City, MO
    I might be a bit biased.....but.......
    http://www.grandprixforums.net/threa...s-98-02-GT-GTP
  15. #15 Re: Where to start, upgrading GTP
    Feb 2015
    Louisville, KY
    Awesome thanks! Love seeing and learning all these great things about my GTP. Really a great help!
  16. #16 Re: Where to start, upgrading GTP
    Feb 2015
    Louisville, KY
    Tomorrow I will be beginning the maintance starting with buying NGK spark plugs and also some aftermarket wires. Any ideas on what wires to get? Does it really matter?
  17. #17 Re: Where to start, upgrading GTP
    cheap parts store brand wires do just fine. get a set with a lifetime warranty. make sure you get iridium plugs too.
  18. #18 Re: Where to start, upgrading GTP
    Feb 2015
    Louisville, KY
    so I'm guessing my local autozone or orileys will have these. So I should get NGK plugs but the iridium kind? With all honesty idk what iridium means but I'm here to learn.
  19. #19 Re: Where to start, upgrading GTP
    iridium is a type of plug, its what came in your car, they will last you 70 to 100,000 miles.
    DO NOT GET PLATINUM PLUGS. car wont like em, and they cost more too, so its like tossing money in the trash.
    wires dont really matter. iv ran autozone wires, now im on advance auto wires. both work fine.
  20. #20 Re: Where to start, upgrading GTP
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    NGK TR55IXs or Autolite XP606s or AcDelco 41-101 will be a good replacement plug.
    2012 F150 STX
    - Gonna be a race truck
  1. 08 upgrading
    By Deanpope2 in forum 04+ Specifics
    Last Post: 01-21-2015, 06:56 PM
  2. Upgrading your suspension?
    By OrangeL67 in forum Brakes/Suspension/Chassis
    Last Post: 08-24-2012, 03:13 PM
  3. Upgrading pullys
    By CoolblueGTP2000 in forum General Grand Prix Discussion
    Last Post: 08-21-2012, 10:38 AM
  4. upgrading performance
    By ndwings11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2009, 03:11 PM
  5. Fan Upgrading...
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 08-16-2008, 08:42 AM
