Hi my abs and traction light will not go out scanner is not picking up any codes.. I cleaned all the hub sensors out replaced the front 2 hubs because one was bad and tested the harness's. I had to unplug my display to get the beeping to stop... My abs module is making a ticking noise?? I have been told that may be the problem? If anyone has any other input it would be awesome at this time hahah
