Thread: Bought a Turbo Kit getting ready for install Block off m90 or Keep it? Why
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Bought a Turbo Kit getting ready for install Block off m90 or Keep it? Why
    Jul 2014
    Virginia
    I am also planning on using stage 4 heads and a stattama st5 turbo cam on my extra block for the BIG turbo build. The stage 2 cam ported heads and stock valves arent gonna get me where I wanna go.
  2. #22 Re: Bought a Turbo Kit getting ready for install Block off m90 or Keep it? Why
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    The biggest concern here shouldn't be the heads and turbo ect.. the first thing you should spend the money on is the gmr parts for the trans. Without that all you will have is broken transmission every time you go above 400-450whp and will be limited. The other stuff you can get any time but not the gmr stuff.
    If You Cant Hear The Whine You're Too Far Behind...
  3. #23 Re: Bought a Turbo Kit getting ready for install Block off m90 or Keep it? Why
    Jul 2014
    Virginia
    Quote Originally Posted by GTP89 View Post
    Like I told that guy Will surely replace the 7/8"chain that already replaced the stock chain set when it breaks. The rest of the stuff in the trans has been replaced also if I could find the post from the guy I bought it from I wouldve linked it. Wasnt aware a 7/8 chain was a grenade waiting to go off...?
    Need this, need that. Itll all get done one step at a time.
    Not that it matters but that stuff is all future thought. I have already removed all the stock components for the most parts and replaced them.
    that would include the stock transmission the stock block stock heads its all sitting right next to the car and now im removing the headers to put the power log and ported rear manifold on to bolt the turbo crossover in.
    Im going to remove the impellers. Thanks.
  4. #24 Re: Bought a Turbo Kit getting ready for install Block off m90 or Keep it? Why
    Jul 2014
    Virginia
    http://www.grandprixforums.net/threa...e-delete/page2
    Doesnt have the details in there anymore. Im pretty sure the headers I just started pulling off of the car I bought from him also. I also bought his ported m90 and LIM. I looked his email up in my paypal and asked him what the trans specs were. Ill post em when he gets back to me.
  5. #25 Re: Bought a Turbo Kit getting ready for install Block off m90 or Keep it? Why
    Aug 2011
    'Merica
    Contact GMRBadass for all of your unobtanium trans parts. Not sure what he has left, but he's a good guy. You also should contact Triple Edge Performance for any and all of your trans questions. Mr GMR and TEP won't steer you wrong.
  6. #26 Re: Bought a Turbo Kit getting ready for install Block off m90 or Keep it? Why
    Feb 2009
    flintnasty MI
    The m90 does not make a turbo setup worse... it will make it spool faster but overall its just spinning dead weight when you make boost on the turbo side... which typically is instantly anyway.
    It would probably help my fiero alot if i put it on... youll make enough power either way to melt the tires so it doesnt really matter
  1. Ready to install SSC's? Which is front?
    By GrandpaAl in forum Brakes/Suspension/Chassis
    Last Post: 05-09-2011, 10:38 AM
  2. Bought ready to pull the trigger, what do y'all think?
    By 6 Shooter in forum 5.3L V8 (LS4)
    Last Post: 11-21-2010, 01:05 PM
  3. ready for header install...PCM????
    By ionroller in forum 04+ Specifics
    Last Post: 09-02-2010, 03:50 PM
  4. Turbo Civic Vs. Small block Bronco !
    By Meemperor in forum Track Sessions and Kills
    Last Post: 02-02-2008, 05:40 AM
