Thread: Top Swap having horrible idle, no power on throttle
Results 1 to 20 of 67
  1. #1 Re: Top Swap having horrible idle, no power on throttle
    sounds like a vac leak. you get the hvac line on the open port a top the sc yet? if not thats a leak right there.
    if thats been hooked up, get some carb cleaner and spray around the engine, if the idle jumps up when sprayed you found your leak area.
    spray the sensors too, evap, map, and bbv, the black round thing on the side of the blower with vac lines to it.
  2. #2 Re: Top Swap having horrible idle, no power on throttle
    May 2014
    New Mexico
    Yeah I got that fixed.
    Okay, So i used your method and found two vacuum leaks. One of them I fixed, the other one is when I spray the Throttle position sensor. How do I fix that? what does that mean?
  3. #3 Re: Top Swap having horrible idle, no power on throttle
    May 2014
    New Mexico
    I also found this unplugged. Don't know what it goes to or if it's causing any of the trouble I'm having. It's right underneath the fuse box.
    http://s1113.photobucket.com/user/02...D=1&sort=1&o=0
  1. Throttle CEL(s) No Power
    By Crocitto49 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-22-2013, 11:26 PM
  2. 2000 GT stall at idle and when let off throttle
    By burgundybullet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2013, 09:28 PM
  3. Throttle Body to vacuum line connector '99 Grand Prix (Also, erratic idle issue)
    By killswitch83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-05-2012, 05:52 PM
  4. warm/hot start HIGH rev idle/ sticking throttle??
    By rschap1 in forum General Tech Discussion
    Last Post: 04-03-2012, 01:26 PM
  5. Throttle bounces at idle AND while driving
    By navillus in forum General Tech Discussion
    Last Post: 05-30-2010, 04:48 PM
