Thread: Newer GT S/C Mods
Results 1 to 20 of 23
  1. #1 Newer GT S/C Mods
    Jan 2009
    petawawa
    Hey, I just joined sight after detail searching the net with no luck for "info"
    I have a 2006 Grand Prix GT2 3.8 series iii, Supercharged.
    First, how do I find performance parts ect...? they all seem to be for
    "pre 2000" GP's.
    Second, I want to make mods, but am unsure of what... and what first.
    Any help is good help.
    Thanks.
  2. #2 Re: Newer GT S/C Mods
    ..first question, where do you want to go with the car? do you want a street beater than you can run out some ricers or do you want a corvette stomping FWD beast?
    decide what you want and then we can tell you what you need to get there.
  3. #3 Re: Newer GT S/C Mods
    Jan 2009
    petawawa
    I would like to tap into her potential for street use... it's my main vehicle... but ya know... goal = proud to open the hood or the throttle without being "all show no go"
    make sense?
  4. #4 Re: Newer GT S/C Mods
    yeah, so youre looking for something entertaining to drive on the street while keeping reliability. that sounds exactly like the common 3.4 pulley setup, but with your genV supercharger you might need a bigger pulley.
    i recommend you look into these items:
    tuned PCM
    180* thermostat
    autolite 104s
    ZZP powerlog
    3" downpipe (bolt in w/ubend delete)
    3.5 supercharger pulley
    thatll give you roughly 240-250 whp and the ability to run a mid 13 at the track if you know how to launch the car. if that leaves you wanting more, you know where to ask.
  5. #5 Re: Newer GT S/C Mods
    Jan 2009
    petawawa
    This is exactly the advice I'm looking for...
    Now if it's not too much. is it possible I can get an explanation of why each of these mods.. in relation to their "stock" counterparts... also "where to buy"
    Knowledge is power.
  6. #6 Re: Newer GT S/C Mods
    Charles City, IA
    Everything on that list can be found at ZZPerformance. I would recomend getting an overkill pcm tho. That Site is :: Overkill Motorsports ::.
    SMGPFC Two Nipple General
  7. #7 Re: Newer GT S/C Mods
    Charles City, IA
    As for what they will do:
    Pcm-higher shift points, better fueling tables, sooner fan turn on and much more
    180 tstat- help it run cooler
    autolite 104's (spark plugs)- One heat range cooler than stock (not need untill pulley drop)
    Powerlog- Replace the factory front exhaust manifold
    down pipe- replace factory down pipe and removes u-bend in exhuast (not sure if the 04+ have a u-bend
    3.5 inch pulley (recommend the multi pulley system for when the mod bug bites again) gives you more boost (should be the last thing you get on the list)
  8. #8 Re: Newer GT S/C Mods
    Jan 2009
    petawawa
    very helpful.
    thank you guys very much.
    now it's shoppin time.
  9. #9 Re: Newer GT S/C Mods
    Donating Users chrisb's Avatar
    Bucyrus, OH
    maybe a a set of headers if its in your budget, and a pcm would wake that thing up.
    1. A tuned pcm depending on who does it will get rid of stock factory settings (DONT GET A CHIP! there worthless). like speed limiter, raised shift points, slightly harder shifting (so the clutches last longer). um some get rid of the torque abuse mode so that you can launch harder.
    2. 180* thermostat is colder then stock (stock 195*) this will help keep kr (knock retard) or detonation down. also people say gas mileage will go down a bit, but it allows you more security if you go down a pulley size.
    3. autolite 104 spark plugs are a colder plug then stock and help keep kr are down.
    4. a larger downpipe then the stock one will free up hp and also keep kr down because of less restriction.
    5. a zzperformance powerlog or plog is a aftermarket front exhaust manifold that is better then porting a stock exhaust manifold. just like the downpipe you get better exhaust flow and it helps keep kr down.
    6. a 3.5 supercharger pulley is 3 sizes smaller then the stock pulley (stock is 3.8 inches across) this will increase boost but you cant just put a pulley on with out supporting modds like everything listed above or you will see increased kr and to much of that and you can say bye bye to your motor.
    hope that helps
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  10. #10 Re: Newer GT S/C Mods
    Bucyrus, OH
    well **** looks like someone beat me to it!
  11. #11 Re: Newer GT S/C Mods
    Jan 2009
    petawawa
    ok awesome...
    so I am to assume that knowing "about" knock retard is a good idea and avoiding it while making upgrades is my plan?
    so can anyone explain knock retard? does it have anything to do with burn quality or octain?
    -- I do know a thing or two about engines.. just might be the way things are said throwing me off is all.
  12. #12 Re: Newer GT S/C Mods
    knock retard is good esentially. it stops your car from actually knocking by decreasing timing. but yes, the more KR you have the more likely you are to chip a piston.
    knock can also be called 'pinging'.
  13. #13 Re: Newer GT S/C Mods
    Barksdale AFB, LA
    A sticky in this section explains octane, kr, and how they relate.
    http://www.grandprixforums.net/f18/w...here-1507.html
    2009 Subaru Impreza WRX STI
  14. #14 Re: Newer GT S/C Mods
    Jan 2009
    petawawa
    right.
    I will read up on KR.. and Thanks again for the Mod suggestions and explanations.
    Very Helpful!
  15. #15 Re: Newer GT S/C Mods
    Donating Users blowfishRus6's Avatar
    g.a.
    there is scan tools to measure KR. droping pullies i would look into one.
    the point of the mods (besides the pullie) is to free up air flow with the engine, thus reducing KR and allowing you to drop pullies.
    exhaust frees up air flow along with internails. rockers, cam, bigger heads.
    pullie is the last mod you want to put on.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  16. #16 Re: Newer GT S/C Mods
    Bastard Reptile's Avatar
    Kansas City, MO
    After reading up on the Octane thread, I would suggest you look for yourself some type of scanner for your car. Something to monitor what is going on with the engine and such. My favorite has always been the Aeroforce Interceptor gauges. They're slightly expensive, but you'll thank yourself for getting one. You can always see what's going on, and you'll know where your limit on mods are.
  17. #17 Re: Newer GT S/C Mods
    Aug 2008
    KCMO
    06gt2s/c keep us informed when you get this done im looking to do the same mods if i cant find a decently cheap gxp to have fun with
  18. #18 Re: Newer GT S/C Mods
    Jan 2009
    petawawa
    Quote Originally Posted by Reptile View Post
    I will look up that scanner... looks like a good idea.
    I will have to take my time with these upgrades as I'm gonna be saving up one peice at a time.
    I'll be posting when I get stuff done, with pics and such.
  19. #19 Re: Newer GT S/C Mods
    g.a.
    i would start off with an intake (you can make your own for cheap, just try and run it into the fenderwell, or tdc has a real nice FWI for cheap) but you can hear the supercharger scream then. a MUST HAVE first mod i would say. then i would do power-log or downpipe next. then thermestat, plugs, tune and 3.5 and enjoy
    its slow.
  20. #20 Re: Newer GT S/C Mods
    g.a.
    with the intake and exhaust tho it will pick up some performance till you can drop pullies.
    something to kind of keep you excited till you get your pullie
    its slow.
  1. Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    By Sinister Performance in forum PCM Tuning
    Last Post: 10-27-2017, 12:55 PM
  2. New member with newer grand prix!!!
    By 08grandprix in forum Introductions/Noob Questions
    Last Post: 10-28-2008, 06:47 PM
  3. Tried to run a newer Stang GT
    By Quicklynx in forum Track Sessions and Kills
    Last Post: 10-23-2008, 07:39 PM
  4. Considering a 05 or newer GP
    By kimbo in forum Off Topic Discussion
    Last Post: 09-21-2008, 09:05 PM
  5. best first mods to do
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2007, 07:50 AM
