Thread: Bell housing bolt
Results 1 to 20 of 26
  1. #1 Bell housing bolt
    Dec 2014
    Remington IN
    What is the trick to getting the bracket off behind the power steering pump so you can get to the backwards bell housing bolt?
  2. #2 Re: Bell housing bolt
    Mar 2014
    Tucson
    No trick. A lot of extensions, good aim, and a little luck. Didn't have to take anything other than the tire and splash shields off IIRC. Maybe the oil filter...
    It's tight. No doubt about it!
  3. #3 Re: Bell housing bolt
    May 2008
    Schuyler, NE
    Iirc, I've had good luck with a 3" extension and leaning over the motor from the top to get the 2 on the block. The 2 bolts in the diff cover should be pretty easy from the wheel well. You also may need to pull the oil pressure sensor.
  4. #4 Re: Bell housing bolt
    take that bracket off then from the wheel well you can see the bolt. use a 3 foot extension and your wrenching from the wheel well.
  5. #5 Re: Bell housing bolt
    Dec 2014
    Remington IN
    Thanks, The bracket is what I was struggling with. But I got it last night. Alot of determination and no fear of busted knuckles involved. Bolts very tight!
  6. #6 Re: Bell housing bolt
    Dec 2014
    Remington IN
    Thanks.
  7. #7 Re: Bell housing bolt
    Dec 2014
    Remington IN
    Thanks you.
  8. #8 Re: Bell housing bolt
    I was going to ask what you were working on..
    Bonnevilles and some other cars had a ps bracket as well.
  9. #9 Re: Bell housing bolt
    This.
    It's even a billion times easier with the head and manifold out of the way, lolol.
  10. #10 Re: Bell housing bolt
    Heck..even if the exhaust manifold is the only thing missing..lol
    I've successfully removed the backwards bolt and pulled a motor out w/o taking off the passenger tire.
  11. #11 Re: Bell housing bolt
    GT Level Member 99GPGTP's Avatar
    Rome GA
    i used my 3ft 1/2 extension that reduces to a 3/8 and put a swivel socket on and got right on it with only removing the bracket that bolts to the trans and engine. i used a ratchet and deep socket to get the two bolts that go in the engine.
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  12. #12 Re: Bell housing bolt
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Ahhh, the "***** bolt" strikes again. Its rather easy with enough extensions.
  13. #13 Re: Bell housing bolt
    Anyone reading the thread might understand..he's asking about the diff to engine bracket.
  14. #14 Re: Bell housing bolt
    May 2008
    Schuyler, NE
    I was gonna say, lots of you guys failed at reading. But, meh.
  15. #15 Re: Bell housing bolt
    Mar 2014
    Tucson
    Guilty.
    But I don't recall having to take that bracket off to get to the "backward" bolt.
  16. #16 Re: Bell housing bolt
    Can't get trans out if you don't pull that bracket.
  17. #17 Re: Bell housing bolt
    Mar 2014
    Tucson
    Right. But we just unbolted it from the trans at the diff cover, and left the bracket attached to the engine.
    Didn't actually "take the bracket off." I guess I'm splitting hairs though. Just wanting to save someone a little work.
  18. #18 Re: Bell housing bolt
    Dec 2014
    Remington IN
    nice picture of the bracket. thanks for all the help. I know how I'm going to put this thing back together. I'm going to put a re ring kit in the used motor I bought, then put the short block in the car and build the rest of the motor in the car. Should have plenty of access to the hidden bolt and bracket on the install over top of the short block.
  19. #19 Re: Bell housing bolt
    Mar 2012
    NC
    Quote Originally Posted by jfrey View Post
    A little piece of advice...don't re-ring the engine. Once you crack those connecting rods apart and remove the bearings, you then distort the factory bearing. Which means time for new rod bearings. New rod bearings don't like the 3800 for some reason and most people end up with a nice knocking noise in about 500 miles. I say if the cylinder walls look good, run it as is.
  20. #20 Re: Bell housing bolt
    It's a lot less back breaking if you build the engine outside of the engine bay. I reach in and do the bolts by hand. It's not actually that hard.
  1. SOLD White iPhone 4 16GB (Bell) AS-IS
    By Speedy1973 in forum Buy/Sell Other/Misc
    Last Post: 02-15-2015, 09:34 PM
  2. Grand Prix vs Subaru WRX [Bolt ons] and Mitsubishi EVO [Bolt ons] [Videos]
    By ADrugDealer in forum Track Sessions and Kills
    Last Post: 05-06-2014, 12:02 PM
  3. Daytime Running Housing swap from 1 bulb to 2 bulb housing?
    By MK666 in forum Visual/Body Modifications
    Last Post: 06-02-2013, 12:42 PM
  4. Thermostat housing bolt
    By mcsddd in forum General Grand Prix Discussion
    Last Post: 07-06-2012, 01:40 PM
