Thread: Ported Heads and Intense Cam's
Results 1 to 4 of 4
  1. #1 Ported Heads and Intense Cam's
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    I might have a local send my heads out to get ported in plans to go Intense Stage 2 or 3 cam. On Intenses site they state their Stage 2 heads are good for .600 lift. Being so I won't need my guides machined then right? If I plan to go stage 3 cam as the biggest? Just a port job is needed?
    CAM-671 - INTENSE™ Stage 1X Blower Cam, duration @ .050": 210/221, lobe lifts: .321"/.329", valve lifts with 1.60:1 rocker arms: .514"/.526", lobe separation angle: 115, intake centerline: 111
    CAM-672 - INTENSE™ Stage 2 Blower Cam, duration @ .050": 214/222, lobe lifts: .332"/.338", valve lifts with 1.60:1 rocker arms: .531"/.541", lobe separation angle: 115, intake centerline: 111
    CAM-673 - INTENSE™ Stage 3 Blower Cam, duration @ .050": 222/228, lobe lifts: .338"/.344", valve lifts with 1.60:1 rocker arms: .541"/.554", lobe separation angle: 115, intake centerline: 111
    CAM-674 - INTENSE™ Stage 4 Blower Cam, duration @ .050": 235/238, lobe lifts: .375"/.376", valve lifts with 1.60:1 rocker arms: .600"/.601", lobe separation angle: 116, intake centerline: 112
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  2. #2 Re: Ported Heads and Intense Cam's
    Kemmerer, Wyoming
    just send them to Chris Hinson aka orangeL67. you will save a lot and still get amazing performance. just tell him what you want and he should be able to do it
  3. #3 Re: Ported Heads and Intense Cam's
    May 2008
    Schuyler, NE
    I wouldn't buy present day Intense heads.
  4. #4 Re: Ported Heads and Intense Cam's
    hinson heads is3 cam!!
  1. Intense stage 2 heads?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2012, 12:24 PM
  2. XPZ/Intense Stage 4 Heads
    By GTP89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2012, 10:36 PM
  3. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
