Thread: supercharger noise at idle
Results 1 to 12 of 12
  1. #1 Re: supercharger noise at idle
    Bastard Reptile's Avatar
    Kansas City, MO
    The supercharger will rattle if any of the bearings are worn, or if the coupler is going bad.
    A whine usually leads to a power steering pump, or maybe one of the idler/tensioner pulleys also.
    Start by taking off the supercharger belt, start the car and see if the whine goes away. If it does, then check all of the other pulleys on the supercharger drive with the engine off.
    Check for play in them, see if they "catch" because of a bad bearing.
    I've even seen where the belt whines.....it sounds weird I know, but it happens.
  2. #2 Re: supercharger noise at idle
    Jan 2009
    St. Augustine, FL
    Thanks for the insight and information. I changed the SC fluid and haven't heard the noise since. The belt is a little worn, and there's alot of "belt powder" on the cooling over flow tank and in the front of the engine. GM replaced a valve cover gasket on a recall, and until this happend I wasn't paying attention. Thanks again....
  1. Supercharger noise, rattle HELP!
    By Mvfootball1 in forum General Tech Discussion
    Last Post: 08-26-2010, 04:49 PM
  2. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
  3. Stumble at idle
    By lowdeuce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2008, 10:26 PM
  4. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
